WhiteRhino's Latest Mods - Page 51 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 10th, 2013, 12:35 PM   #1001
You got the left in the Al crack creek section. Following you I look over at a rock and point out to randy the Burgundy paint left on it.
Old October 21st, 2013, 07:58 PM   #1002
After twisting a couple driveshafts on pavement with the stickies & spool, I ordered a Grizzly locker from Ironman Offroad. Many people had said they were surprised that I twisted a driveshaft instead of an axle shaft. Well, I'm not one to disappoint.
Opinions on reusing or replacing the shaft, especially knowing that I am ditching the spool & going to a locker?
So, then I pulled the Hi-9 center section & I found this little issue.
I had read somewhere that True Hi-9 was having trouble getting gear sets. Here's hoping that's not true. If so, I'm fubarred.
At the very least, the jeep won't be making it to the Mustache Run.
Old October 21st, 2013, 08:05 PM   #1003
chevotass
chevotass's Avatar
ouchhiee
Old October 21st, 2013, 08:07 PM   #1004
Cheater tars are hard on stuff, should have stuck with all the senseless spinning.
Old October 21st, 2013, 08:15 PM   #1005
Tab
Tab's Avatar
Why don't you just admit you can't grow a mustache?
Old October 21st, 2013, 08:15 PM   #1006
Please don't tell my wife that.
I haven't liked the spool & stickies for some time. Looks like I waited to long to get around to the swap.
Tab, you are right, I WON'T grow a mustache.
Old October 21st, 2013, 08:23 PM   #1007
Grassman
2jz specialist
Grassman's Avatar
Tab, you are right, I CAN'T grow a mustache.
Old October 21st, 2013, 08:23 PM   #1008
lgottler
lgottler's Avatar
I still don't understand why a locker instead of a spool will make a difference. Yes if you only turn by coasting with your foot off the gas. But if you have any power applied the locker is just like the spool....I is confused about it.
lgottler is offline   Reply With Quote
Old October 21st, 2013, 08:26 PM   #1009
I twisted a driveshaft in a paved parking lot with brand new asphalt & it was wet. Just coasting into a parking spot made it bind.
Old October 21st, 2013, 08:44 PM   #1010
liv2mx
i like jungle gym's.
liv2mx's Avatar
id run that ring and pinion..shaft..no.
Old October 21st, 2013, 09:02 PM   #1011
kkodet
kkodet's Avatar
Me too. I've driven Samis with welded rears on the street quite a bit with no issues.
Old October 21st, 2013, 09:04 PM   #1012
You haven't with red label stickies. HUGE difference.
Old October 21st, 2013, 09:05 PM   #1013
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
with sticky tires ? big difference
Old October 21st, 2013, 09:06 PM   #1014
scottie
Eye candy
scottie's Avatar
40 HP and 700 lb on the rear axle make a difference
Old October 21st, 2013, 09:16 PM   #1015
lgottler
lgottler's Avatar
Wait. All this was caused from a Dairy Queen run?
Old October 21st, 2013, 09:21 PM   #1016
Cool parts peddler
Ironman Offroad's Avatar
Change it all.
Nothing spoils a trip faster than damaged stuff you knew you should change but played cheapskate. And now it is broke and you friends get to laugh at you while they drag your broken junk to the trailer.
Old October 21st, 2013, 09:23 PM   #1017
Change it all.
That's always been my theory too. Sad but true.
Hi-9 website says $525 for replacement gears.
Old October 21st, 2013, 09:33 PM   #1018
Strangler
Strangler's Avatar
I smell mustache fear.
Old October 21st, 2013, 09:53 PM   #1019
Tab
Tab's Avatar
Change it all.
Says the guy who sells the parts...... Lol
Old October 21st, 2013, 09:53 PM   #1020
Tab
Tab's Avatar
Rightly said though!
Tags
meballs
Page generated in 0.46566 seconds with 84 queries
