WhiteRhino's Latest Mods - Page 28 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2013, 09:21 PM   #541
benny87
Young Gun..!
benny87's Avatar
Man I am jealous... Nice setup Jim...!
benny87 is offline   Reply With Quote
Old February 11th, 2013, 06:29 AM   #542
The jeep is officially parked as things will be changing over the next few months. After 5 years of good wheeling, all of my links have worn out. Prior to our trip to KOH I replaced all but the rear uppers with new 1-3/4 x 3/8 DOM & new 1-1/4 shank Johnny joints. I didn't replace the uppers because I currently can't get one of the frame end bolts out. This is because when I did the suspension, I had the NP231 case in it and now with the Atlas, the bolt won't clear. I didn't figure this was a huge problem but as it turns out, it was. Coming down Outer Limits in the dark I had a big clang and the jeep shifted sideways. Turns out one of the welds at the rear of the upper gave out.
My body is totally trashed both from some hard use and rust. All of the body mounts have rusted out and the tub is being held in place by the 6 points of the roll cage. I can no longer use my hard doors because the tub is so tweaked that they won't close. So, the body swap needs to happen. While the body is off, I'll modify the upper link mount to be able to get the bolt out without dropping the t-case. I will also do some maintenance on the frame and fix the fubarred body mounts. I've been running fiberglass front fenders and one of them is cracked in half. So, a new set of tube fenders will be installed. My rocker guards were originally built to blend with my fender flares which were removed years ago. So, the front of the rocker guards have always been a little goofy. With the abuse, they are no longer straight. So, they are getting pitched. I am still undecided if I will boatside it or do a new set of rocker guards. I am leaning towards rocker guards again because the wife already has a tough time getting in and out.
I'm ready to back off from some of the hardcore wheeling. I've had the good fortune to wheel some of the toughest stuff in North America and am ready to stop beating the jeep so hard. We no longer enjoy driving the jeep around town or using it to buzz up to DQ in the evening. This is something we miss. The rear spool is a pain on the pavement and has contributed to 2 twisted rear driveshafts. So, I'm going to install an ARB in the rear. The 2 piece front driveshaft works great but spins all the time with the drive flanges so I 'm going with the new Yukon lockouts and will use the drive flanges during any hardcore trips. I am undecided if I will keep the Krawler stickies or not.
I've been wanting to replace the high back Bestop seats for some time with suspension seats. I don't want race buckets because of the tight confinement and I also want flip back/recliner seats for ease of access behind the seats. While at KOH, I did some shopping for seats. Both PRP and Mastercraft were there so I had the opportunity to sit in both with a 30 second walk back and forth. I decided on a set of recliner suspension seats from PRP. I scored the set of 2 for $700 cash if I took them with me.
Before I get started, I have a couple weeks of things to do around the house and then strip the donor jeep apart and part it out. So, the jeep will be sitting for a month or 2 and then the work will start.
Old February 11th, 2013, 06:34 AM   #543
knaffie
knaffie's Avatar
Wow, that's a heck of a list!
I forecast more and more people doing what you're doing - making their streetable vehicles more streetable.
Old February 11th, 2013, 06:37 AM   #544
Mr.Green
I can levitate!
Mr.Green's Avatar
ARBs FTW. Maybe what you really need is Testosterone Replacement Therapy? IDK.
JK, Having a streetable Jeep is kinda a nice option. I hope mine stays that way, well gets that way and then stays that way.
Old February 11th, 2013, 08:45 AM   #545
Strangler
Strangler's Avatar
Sounds like a good plan Jim. As you always say, "if the wife's not happy, move on to her friend", right?
Old February 11th, 2013, 09:52 AM   #546
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
LOL.
Let me know when you need a hand.
Old February 11th, 2013, 10:29 AM   #547
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
With the wife?
Old February 11th, 2013, 10:30 AM   #548
Cool parts peddler
Ironman Offroad's Avatar
Good choices.
Old February 11th, 2013, 11:10 AM   #549
dreezy
Haggard Fab
dreezy's Avatar
Aren't those ugly front fenders kind of your calling card though?
If you high-lined the fenders and lowered it some, do you think the wife difficulty level would be relatively the same with a good boatsiding?
Old February 11th, 2013, 02:45 PM   #550
Ugly? I kinda thougth my always friendly demeanor on the trail was my calling card.
Hi-lined fenders would make no difference in my ride height. For normal wheeling I have about 4" of up travel with my front axle about 1/2" short of hitting my frame rail. Depending on pressure in the air shocks, I am at about 21-1/2 to 23" belly clearance, which is about right for 104" wheel base. The only way to lower the jeep would be to remove the 2" body lift. However, I like it since it allows access above the frame rail and everything is built around that offset. To lower the tub would require changing all cage mounts and doing some cutouts in the tub. I don't see it worth the effort.
Old February 11th, 2013, 03:55 PM   #551
Bones
Bones's Avatar
ARBs FTW.
puke
give me a competiton spec yukon zip locker instead
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 11th, 2013, 04:39 PM   #552
Originally Posted by Bones View Post
puke
I've already talked to Dale about it. They are not available yet for a 9".
Old February 11th, 2013, 04:51 PM   #553
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i have never owned a ARB and never will. I have seen more peoples races(i know your not racing but reliability sucks) throwin away over the last few years then i can count on all my fingers and toes, between air leaks, compressor failures and generally shitty design for the nine inch
Old February 11th, 2013, 05:08 PM   #554
Wramblerguy
Wramblerguy's Avatar
Why not a hanging chain step on the passenger side for the wife
That's what is on my dads jeep and it makes it much easier to get into and it doesn't get hung up on obstacles
3rd generation jeeper
Old February 11th, 2013, 06:09 PM   #555
Bones
Bones's Avatar
this, times a billion, for every axle (not just 9").
Fail me locked, not open.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 11th, 2013, 06:19 PM   #556
I ran ARB's (old style) for years without a failure. (other than the bug (8 legged kind) that got in my air line) And I know a lot of people who are very happy with them running some tough stuff. No matter what I do, I want to get away from the spool. I'm not a big fan of Detroits either. (yes, I have one in the front)
I agree with the fail me locked but until they offer it, I can't use it.
I just got off the phone with Mike from HI-9. Being a business owner, he's not there to advise too much on different lockers or piss off any of his suppliers. However, he acknowledges the good and bad of each product and knows the stories of ARB's. Summarizing a long conversation of each product, here's his story. Yukon has a Grizzly that is especially designed to work in the HI-9. If you buy the right Grizzly model number, it's configured to work with the Hi-9 and the thrust bolt. He says they have not had any complaints since Yukon made this special edition. He also recommends the comp spring for my application. So, time to have Dale do some pricing for me.
It's an idea but not something I'm interested in.
Old February 11th, 2013, 06:22 PM   #557
Bones
Bones's Avatar
I don't care if it is caused by unicorn horns and dragons blood, a failure is a failure.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 11th, 2013, 06:25 PM   #558
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
The guys over at Rocksolid performance have had a lot of good to say about grizzly lockers. They have sold a ton of them. I am debating on using them or detroits in the buggy. They have one of the grizzly lockers sitting on their counter that you can work by hand. It seems like a good design.
Old February 11th, 2013, 06:27 PM   #559
chevotass
chevotass's Avatar
i love my arbs. have had one failure which took a whole 5 minutes to fix the airline. and i was good to go again.
haters are gonna hate jim. and incorporate a york for your compressor and you have your onboard air. i have it on mine if you need any ideas for brackets.
Old February 11th, 2013, 06:28 PM   #560
chevotass
chevotass's Avatar
what fails in an arb?
Tags
meballs
Page generated in 0.48776 seconds with 84 queries
