WhiteRhino's Latest Mods - Page 26 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2012, 06:37 AM   #501
benny87
Young Gun..!
benny87's Avatar
Glad to hear that it worked well Jim...!
benny87 is offline   Reply With Quote
Old September 10th, 2012, 06:56 AM   #502
At this point I didn't really notice any difference from the Hydro assist since it worked well also. I'm suspecting the big difference in the rocks.
I forgot to mention that I pulled my front pull down winch. We wanted to tuck the steering up high & I had a conflict at full stuff. I never really used the pull down much and I can always use the winch if need be. Everything's a tradeoff.
Oh, and thanks to Dale @ Ironman for being a top notch supplier.
Old September 10th, 2012, 10:28 AM   #503
crunchedtj99
Heard it worked quite a bit better than donnies steering ;) lol. So for my xj buggy, since you have experience with both would you say build an assist setup or full hydro?
crunchedtj99 is offline   Reply With Quote
Old September 10th, 2012, 10:32 AM   #504
knaffie
knaffie's Avatar
I fought constantly with my assist setup. The full hydro setup is much simpler and easier. Easy decision.
Old September 11th, 2012, 12:22 PM   #505
4Bangler
Jackstand Wheeler
4Bangler's Avatar
I may have missed it (I scroll past the ) did you sell your old assist setup?
Old September 11th, 2012, 12:39 PM   #506
Strangler
Strangler's Avatar
He did, but I think its for sale
Old September 11th, 2012, 01:17 PM   #507
Old January 15th, 2013, 10:26 PM   #508
Well a few updates half of which is the garage. I picked up a used 2 post hoist. The problem is that I have a 8 1/2 ft ceiling in my garage and I needed to put the hoist off center. So, the gang came over and we installed a beam, cut out half the joists and put in the hoist. I also had to drill a 4" diameter hole in my roof for the cylinder to poke up through. That got capped off with a 4" PVC stink pipe and cap. By using the beam, I was able to save the other half for a loft for storage.
The next thing is that I picked up a small engine lathe to do some work. First project is a new driveshaft.
Since having the stickies, I have twisted 2 driveshaft splines. The worst one on the left was done in the CVS parking lot @ St. Helen. Seems brand new blacktop, rain and stickies don't mix very well. I'm thinking of ditching the spool and going back to an ARB.
I had a variety of misc parts laying around and managed to piece together a new driveshaft. This one is 2 3/4 x 1/4 wall.
I also finally gave up on the old bent up links with Ballistic joints. I actually blew a joint apart while at Curly's last November. So I built a new set using Currie Johnny Joints. 1-1/4 shank tapped into 1-3/4 x 3/8 DOM.
Old January 15th, 2013, 10:37 PM   #509
knaffie
knaffie's Avatar
Totally jealous of that lift. Your and other'sfeedback when I was asking a while ago was the reason I went with the JJ's over the Ballistic Joints. Glad ya got the good ones in there now. :p
Old January 16th, 2013, 01:23 AM   #510
Doc
Doc's Avatar
I want to know some info on building drive shafts, I'm going to be needing them pretty soon. You should give me the low down
Doc is offline   Reply With Quote
Old January 16th, 2013, 01:28 AM   #511
Doc
Doc's Avatar
Body swap is on hold till after KOH 13. Gonna do full hydro next. Although I may pull my rocker guards and mock up a boatside setup before KOH.
I'm interested in those rockers if you do go with a boat side setup, that's of course if they are for sale.
Old January 16th, 2013, 05:44 AM   #512
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
@ the date on post 508
Edit
Hmmm, now it changed....
Old January 16th, 2013, 06:14 AM   #513
If you don't have good parts laying around, buy your first driveshaft. Go with at least 1350 joints. Still haven't decided on the rockers/boatsides. Well, actually I have. I like the idea of boatsides but the wife likes the idea of a step to get in and out. Happy wife.... happy life. But I don't know if I'll keep the same ones or get Tab to make me something new.
Old January 16th, 2013, 07:07 AM   #514
firehawk
Live Action!
firehawk's Avatar
After playing in the rocks at the mounds last weekend I will be boat siding my YJ, at least one side
Is that a Hi9 rear axle?
Would you be willing to share the details on the front 3 link? That is going to be my next suspension upgrade and I have never done one before.
It would help if I could see more pictures of the mounts and some measurements to get me started.
I might be willing to trade a car to someone of they wanted to do the work.
Old January 16th, 2013, 08:49 AM   #515
Yes it is.
Sure, I can share the front. One point from the get go, if you are going to go full hydro, you may want to consider a 4 link. Many say they flex better. I've never had a problem other than I want to move my sway bar to the rear to get more flex.
Old January 16th, 2013, 06:04 PM   #516
kixx007
Certified Ypsilantian
kixx007's Avatar
Garage looks different! I'll be over soon to change the air in my tires.
kixx007 is offline   Reply With Quote
Old January 16th, 2013, 06:08 PM   #517
No problem. I have a big knife to let the old air out.
Old January 16th, 2013, 07:23 PM   #518
crosseyed cat
safety cone killer !!!
crosseyed cat's Avatar
Cool set up! I guess stickies are no joke ,with that shaft. Nice job on the clean upgrades
crosseyed cat is offline   Reply With Quote
Old January 16th, 2013, 07:27 PM   #519
liv2mx
i like jungle gym's.
liv2mx's Avatar
go get a drive shaft from a 1 ton truck and they have the bigger slip shafts.that should cure your twisting of the splines. upgrading both of mine.big difference in size.
Old January 16th, 2013, 07:54 PM   #520
knaffie
knaffie's Avatar
Nothing else sticks better. Great tires, if you can keep air in them.
Tags
meballs
Page generated in 0.36457 seconds with 84 queries
