WhiteRhino's Latest Mods - Page 17 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 19th, 2008, 11:51 AM   #321
Originally Posted by Bones View Post
the con is that WHEN (not if) you finall buy real axles, the tires wont fit unless you have an uber wide trackwidth
Please define "real" axles.
Old September 19th, 2008, 12:00 PM   #322
95geo
newbie
95geo's Avatar
you sure about that?
Old September 19th, 2008, 12:06 PM   #323
Bones
Bones's Avatar
rockwells duuuuhhhhhhh
for some reason I thought you had a build 44 up front
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 19th, 2008, 01:38 PM   #324
Yup, you're right, that's what I need.
Old September 19th, 2008, 01:50 PM   #325
silverxj
Recovering XJ owner
silverxj's Avatar
or go back to 44's ... if they're built right they last.
Old September 19th, 2008, 02:44 PM   #326
Yup, just ask CC.
Old September 20th, 2008, 09:35 AM   #327
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
for the money i have put into my hybrid44/60 front axle a little bit more would have gotten me a solid axle front 60
I'm the man in White.
Old November 16th, 2008, 06:34 PM   #328
Well this is not really an update on any build mods. That's actually the point. It's time to note the quality of engineering and work done by Bryce and Jim. Since June we've hit everything from the dunes for a week to 3-4 times at the Mounds to twice at OSTC to 3 trips to Canada. I've run the snot out of it and twisted it up pretty good with no problems save a couple loose bolts on the hydro assist that we found on the first outing.
Kudos to you both. Thanks again.
Old November 16th, 2008, 07:43 PM   #329
95geo
newbie
95geo's Avatar
I'm glad you're happy with it! hopefully you'll have many more trouble free trips!
get some sticky's on there and you'll probably put a few buggies in their place
Old November 16th, 2008, 09:38 PM   #330
95geo
newbie
95geo's Avatar
[shameless plug for me!]
ohh yeah, I'm "for hire" but not cheap. If you want something of this caliber done let me know and we can talk about options if you are serious.
[/shameless plug]
Old November 16th, 2008, 10:15 PM   #331
scottie
Eye candy
scottie's Avatar
you can do my Liberty, Obama said he'd pay for it.
Old November 25th, 2008, 05:24 AM   #332
ttt because Stan put his ttt.
Old February 18th, 2009, 01:55 PM   #333
Well, since I'm getting old and lazy, I got tired of using my winch for double duty as a front pull down. One of the biggest issues is that I had gotten in a precarious position with my front pulled down. When we decided to pull cable, I let up on the pull down and then it got really tippy. So, I decided to separate the 2 functions. I picked up a T-Max 2300 pound ATV winch from Ironman. It mounts to my front cross tube of the frame, directly underneath my 9000 pound winch.
The cable runs up and over a cross tube that is a frame stiffener in the steering area and doubles as the upper mount for the limiting strap. (note; limiting strap not mounted) I added a 2" diameter pulley on the back side of the tube for the cable. For the moment the end of the cable is mounted to the limiting strap tab. This will move.
Then the cable runs down to a snatch block mounted to the axle and then back up to the cross tube. For the moment I have a cheap snatch block from TSC on the axle. It's only rated at about 500 pounds and I don't think it's going to hold up so I will need to make my own snatch block. This one worked out pretty well though because when I sucked the front end down the thin side plates bent in the compound angle needed for everything to line up. This makes for a great template for a stiffer one.
So now I won't have to crawl underneath in the slop to be able to use my winch when needed.
Old February 18th, 2009, 02:01 PM   #334
robo-3
02 tj
robo-3's Avatar
thats what im doing this spring !
robo-3 is offline   Reply With Quote
Old February 18th, 2009, 03:12 PM   #335
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Nice work Jim. Looks like a tight fit in there.
Old February 18th, 2009, 07:18 PM   #336
VonDirt
VonDirt's Avatar
just read it through.
nice work.
VonDirt is offline   Reply With Quote
Old February 16th, 2010, 08:13 AM   #337
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Exhaust pics. All bolted together with flanges in front of the mufflers. Nothing welded to the frame.
Well, this thread has been quite for a while .
Do you still have the above pictures, without red x's? I am looking for some exhaust ideas on my build.
thanks
RIP FULLSIZE4LIFE
Old February 26th, 2010, 09:42 AM   #338
Sorry, just saw the reply. I had pulled the pics down to make room for new ones. I'll have to go back and look for the exhaust pics.
Old February 26th, 2010, 01:55 PM   #339
benny87
Young Gun..!
benny87's Avatar
Here.
benny87 is offline   Reply With Quote
Old February 28th, 2010, 07:01 PM   #340
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
did you guys rotate the pinion up on that front axle?
sbcrichie is offline   Reply With Quote
Tags
meballs
Page generated in 0.51538 seconds with 84 queries
