WhiteRhino's Latest Mods - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2008, 08:08 PM   #221
MotoX5874
unbound
MotoX5874's Avatar
I had zero problems with it the entire weekend.
really?
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
:tonka:
MotoX5874 is offline   Reply With Quote
Old June 5th, 2008, 09:16 PM   #222
That's the last time I'm gonna back my jeep out of my trailer to help you
It appears that my fuel pump may be taking a nap. It worked fine for the whole weekend till then. Haven't had a chance to look at it.
Dam, don't you have any good vids to post in my build thread? Especially after you posted silverxj struggling up impossible right after I smoked it.
Old June 5th, 2008, 09:31 PM   #223
MotoX5874
unbound
MotoX5874's Avatar
YouTube Video
i was actually impressed at how easy you made it look compared to everyone else :tonka:
Old June 7th, 2008, 04:49 PM   #224
motrctyman
Just The Spouse's spouse
motrctyman's Avatar
Originally Posted by MotoX5874 View Post
really?:tonka:
motrctyman is offline   Reply With Quote
Old June 7th, 2008, 07:12 PM   #225
Just replaced the fuel pump. Good to go.
Old July 23rd, 2008, 09:04 AM   #226
Mounted up the paddles last night for a dune run. With the wider axle and lower belly it should be pretty stable.
With the wider axles and no fender flares I think the sand will be flying.
It looks a little goofy with the shorter paddles since the suspension was set up for a 38-40" tire. But I'm hoping to be able to glide over the dunes instead of bouncing.
Old July 23rd, 2008, 09:06 AM   #227
natureboynate47
natureboynate47's Avatar
that looks sweet
natureboynate47 is offline   Reply With Quote
Old July 23rd, 2008, 09:11 AM   #228
4x Fanatic
Guiness Test Pilot
4x Fanatic's Avatar
You should re-name it "Hacksaw" because it is short, squatty and extra wide now.
4x Fanatic is offline   Reply With Quote
Old July 23rd, 2008, 09:14 AM   #229
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i found with air shocks on the dunes the harder you drive it the better they work
Old July 23rd, 2008, 09:18 AM   #230
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Looks good, let us know how it throws sand and when your gonna be there.
Also, I would like to know how your gearing vs tire size ride etc... works.
RIP FULLSIZE4LIFE
Old July 23rd, 2008, 09:31 AM   #231
benny87
Young Gun..!
benny87's Avatar
Thats pretty sweet lookin.. lol....
benny87 is offline   Reply With Quote
Old July 23rd, 2008, 09:33 AM   #232
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Don't forget your goggles, soemthing tells me you'll need them. It actually looks pretty good, should give ample clearance for when you jump test hill with the 6.0 and new suspension.
Old July 23rd, 2008, 09:44 AM   #233
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
Thumbs up
YouTube Video
Im not bashing the Jeep but looks like it needs bigger tires cus the pig is plowing the Sand and dirt in the video other then that nice YJ
Rockstar is offline   Reply With Quote
Old July 23rd, 2008, 09:45 AM   #234
Only tough thing is I don't have a sway bar setup yet. I drove it last night & got on it hard. It's fast but squirrly.
I already know it throws sand good. Same engine and same tires as before. Just went from 4.56 to 4.88 gears. So it should be a little quicker.
Not planning on jumping. No bump stops.
The pics here are before I reset the air in the shocks. This shows a little under 4" of exposed rod. I'm shooting for 5".
Old July 23rd, 2008, 09:45 AM   #235
95geo
newbie
95geo's Avatar
at first I thought it looked goofy.... but it's starting to grow on me a bit!
get about 5" of shaft showing on the shocks and you'll have a ton of fun out there!
Old July 23rd, 2008, 09:46 AM   #236
Yeah, it could use a little taller tire but note the comment in the post you quoted. I would rather drag the diff in the sand & smoke the hill than have sand clearance & run out of tire speed.
Thanks for the props.
Old July 23rd, 2008, 09:49 AM   #237
I'm just worried about losing control on high speed stuff. With low air pressure & the quick steering without a sway bar it gets loose really quick. I stomped on it last night in 2wd on the gravel road with the paddles & by the time it hit second gear it was hard to control.
Old July 23rd, 2008, 09:54 AM   #238
bearlys2005
bearlys2005's Avatar
Looks great Jim, looking forward to seeing you tear up the dunes...
bearlys2005 is offline   Reply With Quote
Old July 23rd, 2008, 09:58 AM   #239
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
It's only Wed. You probably aren't leaving until Friday, right?
It sounds like you'll have fun.
Old July 23rd, 2008, 09:59 AM   #240
comanche38
comanche38's Avatar
I think it looks great. Does it still fit in the trailer with those on? I had a really loose or squirrelly Jeep and then on the dunes, it got more stabile. Hopefully the same will happen to you. HAVE FUN!
comanche38 is offline   Reply With Quote
Tags
meballs
Page generated in 0.45342 seconds with 84 queries
