my improved rig - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 6th, 2006, 04:01 PM   #1
vwBOY
it's how i roll
vwBOY's Avatar
Default my improved rig
i know it still looks kind of shitty but it is a work in progress
i just got done putting bondo on all of the welds to kleen it up and going to paint it this summer with a black to red fade. it think it looks a lot better than before.
BEFORE:
AFTER:
vwBOY is offline   Reply With Quote
Old April 6th, 2006, 04:07 PM   #2
going-strong
'96 360 sport 4x4
going-strong's Avatar
looks real good...im thinking about building one this summer, any advise?
going-strong is offline   Reply With Quote
Old April 6th, 2006, 04:10 PM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
The only difference I see, is it shrank!
Old April 6th, 2006, 04:16 PM   #4
vwBOY
it's how i roll
vwBOY's Avatar
size doesn't matter it's how you use it
me and buddy build about three a year
if i were you i would build a baja beetle
Old April 6th, 2006, 04:20 PM   #5
going-strong
'96 360 sport 4x4
what engine u got in there?
Old April 6th, 2006, 04:49 PM   #6
deuce228
Redneck Poser
deuce228's Avatar
I think it looks like piss. Can't you at least pretend there is a front on that? It looks like a chevy astro van without a body. Also isn't the exhaust a bit far out/close to the ground to actualy do anything but ride on the road? Why did you waste your time/money on relocating it?
Old April 6th, 2006, 04:52 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
I see icons.. but no pics... need em lrger man, but it does look a LITTLE better
Old April 6th, 2006, 04:59 PM   #8
boggin-machine
boggin-machine's Avatar
anything that coems off of them new swampers u say ordered is just gonan beat hte hell outa the pipe. and hear big tings.
i dont see anydifference besides the rims and wider tires
Old April 6th, 2006, 07:04 PM   #9
vwBOY
it's how i roll
vwBOY's Avatar
i got a 1600 cc with a big bore kit on it makes about a 100 hp or so it goes pretty good
Old April 7th, 2006, 12:08 AM   #10
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Still the same...nothing special. Shit, you might as well buy something that is worth working on.
*2007 Rubicon
*2006 Duramax
Old April 7th, 2006, 01:46 AM   #11
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
You still haven't improved your excellent choice in clothes.
Old April 7th, 2006, 06:56 AM   #12
deuce228
Redneck Poser
deuce228's Avatar
Hey muncher,
Why are you on this board? I mean you don't even seem to aspire to own a jeep or other 4x4(as i do at least). You harass sellers, and post this crap on here. Then your trying to pawn off your lawn equipment on here. Im not quite sure your purpose here. I personally would stop dumping money into something like that and maybe actually get to owning something that holds some sort of value.
Old April 7th, 2006, 10:38 AM   #13
vwBOY
it's how i roll
vwBOY's Avatar
well i'll tell you what i do want to own a 4x4 but i don't have the money to so this is the next best thing. I am going though a hard time right now and i just want to have a little fun with it sorry i you dont like it only thing that matters is that i like it
Old April 7th, 2006, 10:54 AM   #14
Monster4.0
Monster4.0's Avatar
So basically you are saying it's not a 1600cc. I'm assuming you started with a dual port 1600 before the big bore.
Old April 7th, 2006, 11:36 AM   #15
vwBOY
it's how i roll
vwBOY's Avatar
yyes dual port 1600 cc than it got the big bore kit
get the dual port engine not the single port
and make sure you have the heat risers
Old April 7th, 2006, 12:01 PM   #16
Yeah, what are you really running?
I assume sinsc you aren't talking real details, other than JC Whitney terms like 'big bore kit' that you are just running a 1641 setup with a single carb.
You ain't making 100 hp with that, I'd estimate 70-75 or so.
I might build a buggy again, but wouldn't even bother with a VW motor again. The amount of work to make 150 hp (conversion factor, thats 200 *vwman* HP), its too much money.
I can put in a Honda motor making 175 hp for about $1000. i doubt any stock stroke VW type 1 motor is going to make 175 hp. Even if you did, cost of 1914 jugs, cylinders, flycutting & porting the heads, block work, dual carbs, etc, you got $2k into it.
Aluminum block/head, honda B series motors barely weigh more than a fully dressed VW motor (I have lifted both bymyself without a hoist), 8000+ rpm, honda motors or a rotary mazda would be my egnine of choice, with a transporter transaxle (with the diff flipped for a reverse rotation honda motor)
Old April 7th, 2006, 12:06 PM   #17
Generally, the 'big bore' kits are a new set of jugs and pistons that bump the displacement a touch to 1641 cc. They are thinner wall cylinders because they fit into the stock block.
Normally, if you were building a performance engine with the stock crank, you go to 1776, 1835, or 1914 ccs, which are all larger pistons. To fit the cylinder jugs, the engine block must be bored to accomodate the cylinder bases.
Old April 7th, 2006, 12:10 PM   #18
Toivo
Feel lucky?
Toivo's Avatar
Default 1
Hm the only improvement you could possibly do is to cut it up for short steel...you might $300.
Old April 7th, 2006, 12:11 PM   #19
OnlyInMyXJ22
No Money = No Fun
*2007 Rubicon
*2006 Duramax
Old April 7th, 2006, 01:10 PM   #20
Toivo
Feel lucky?
Toivo's Avatar
Default i guess
Buggy 4x4...
Page generated in 0.42861 seconds with 83 queries
