7.3 IDI fuel help plz - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2008, 04:06 PM   #1
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Default 7.3 IDI fuel help plz
So I had a fuel leak from the lines right before the transfer switch on my 93 F-250 I replaced them and now I can't get it running again. Should it really take this long to get all of the air out of the lines?
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old April 18th, 2008, 04:12 PM   #2
Era
1960 willys
There is a bleeder up near the filter but you prolly know that but anyways bleed it till fuel comes out if that dont work, im not shure if this happens on those but on bigger deisls if air gets to the injectors you may have to bleed each one of those off to what other symtoms did it have before you fixed the lines ?
Era is offline   Reply With Quote
Old April 18th, 2008, 05:02 PM   #3
IDIeselman
IDIeselman's Avatar
You may have to fill the fuel filter and crack loose 3-4 lines at the injectors to bleed the air out of the lines. once it starts tighten the lines and let it idle for awhile. Some will start right up after replacing the lines and some are just stubborn and have to be driven hard for a few miles to work all the air out after they start, If your lift pump is in good shape you shouldn't have to crank it very long before it fires.
Old April 20th, 2008, 05:05 PM   #4
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Ok problem Solved some moron reversed the vent and supply line. OOOOPPS
Page generated in 0.22090 seconds with 35 queries
