Jeep Rant (when projects go wild) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2008, 09:53 AM   #1
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
Default Jeep Rant (when projects go wild)
So I spent 5 hours last (8:30-1:30pm) working on my jeep, i am putting the 4.0/auto from a 90 XJ into a 95 YJ 2.5/5sp this should be easy, same manufacturer etc... seems that at some point the wiring went to a power distribution system (?) so i have put the complete wiring harness from the XJ into my jeep, the tail light plugs dont match 5 or 6 wires compared to 3, the fuel pump wiring comes from a different feed so i have to combine the harness, the wiper and heater motor are different plugs and amounts of wires.
i guess i was "lucky" that the steering column plugs were the same. i even had to switch the bolts that hold the bulkhead fitting to the firewall. so i have all these extra plugs in my jeep now powerwindows,locks,mirrors,antanea,power seats and speakers wire plugs galore. i was actually able to hook up all the engine plugs,comp.and tcu plugs without to much trouble only to find out that now i have to install the headlight harness from the XJ also! this does not even include mounting the coil pack,the relay deal and reroute the whole harness under the hood. After all this wiring there is still suspension,brakes and body work to do, if i could rewind 6months of my life i would have just bought a stinking 4cyl and shoved it in there and been on the trail allready.i am sure it will all be worth it when i am done 5 years from now.
my luck it will probably go up in flames when i first hit the key, i will have full coverage on it for that event.
jeepster95 is offline   Reply With Quote
Old April 18th, 2008, 10:04 AM   #2
lovemychevy
Something Clever
lovemychevy's Avatar
dont get discouraged, keep with it, and you will be happy you did when you get to play with the end result
lovemychevy is offline   Reply With Quote
Old April 18th, 2008, 10:09 AM   #3
JEEPR
Playing Possum
JEEPR's Avatar
The light deal is because the Cherokee has turn signals separate from the running/brake lights.
JEEPR is offline   Reply With Quote
Old April 18th, 2008, 10:50 AM   #4
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
thanks for the support, thats why i ranted so that i can continue the progress, i can see it getting done but i cant see it happening quickly like i would like.
Old April 18th, 2008, 11:20 AM   #5
Immortal
NO RELIGION WAT!
Immortal's Avatar
boy are you going to be pissed when you find out the aw4 with t/c is too long
Immortal is online now   Reply With Quote
Old April 18th, 2008, 11:22 AM   #6
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
This is a pretty common swap...
JcrOffroad
Zoom Zoom!
Old April 18th, 2008, 11:23 AM   #7
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Also it's easier to use the XJ PDC under the hood, then splice it into the bulkhead connector outside the firewall. There are like 5 wires that run through the firewall as well.
Use the full YJ harness inside.
We put an 01 XJ drivetrain into a 2.5 YJ last year. Turned out great.
JcrOffroad
Zoom Zoom!
Old April 18th, 2008, 11:24 AM   #8
Immortal
NO RELIGION WAT!
Immortal's Avatar
you need to let things be sometimes
Old April 18th, 2008, 11:54 AM   #9
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
You make that sound easy??????????
RIP FULLSIZE4LIFE
Old April 18th, 2008, 12:15 PM   #10
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
unfortunatly the XJ did not have the PDC and all the wires run into the dash wiring, thats why i swapped all of it, the trans and tcase are allready set when i put the XJ rear axle under it (spring over) i should be all right, the driveshaft is at full stuff right now, if i have to go to a sye kit and custom shaft i will. i located the engine trans tc and motormounts with the shaft connected to the rear axle,the front shaft was fine at this time. the fan is going to be a push electric thru the rad. let me know if i am lost on this set-up, i read a few articles on this swap and hope that i am ok.
thanks again
Old April 18th, 2008, 12:19 PM   #11
jeepnxj96
jeepnxj96's Avatar
you are almost always money and time ahead to just sell the 2.5L pig and buy a 4.0l beast instead of swapping.
Old April 18th, 2008, 12:31 PM   #12
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
yeah but if the 2.5 is bad, which I'm assuming it was from some of his other posts, you wouldn't get dick for it and if he picked up the XJ stuff for cheap why not do it?
71jeepster is offline   Reply With Quote
Old April 18th, 2008, 12:41 PM   #13
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
you need round headlights problem solved
Rockstar is offline   Reply With Quote
Old April 18th, 2008, 12:59 PM   #14
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
i all ready thought that, i have parts from many other letter vehicles going on this so why not a CJ front clip.
YJ tub
XJ drive train
TJ gas filler neck
ZJ rear disc brakes
and yes the 2.5 went bad, 225000 miles hard miles, the YJ would roll in gear down a small slope, the fan flew off and took out the rad. and then the rear leaf spring snapped in half. i was still driving 100 miles a day as it was.
Old November 8th, 2012, 12:37 PM   #15
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
Default HAHA! Glad I found this!
I see why a build thread is so important, I laffed hard when I read my frustration! I just had a nice trouble free summer of playing with this same jeep, the swap got done (I got a 93xj wire harness, plug and play) front drive shaft was 1" short (kudo's to poster) I did the Hack -n- Tap w/ XJ front drive shaft for the rear. I did SOA on the rear with the factory YJ springs, kept the RC 3 1/2 front SUA. Got rid of sway bars, XJ shifter with TJ console. I home fabbed my sport cage (professionally welded at work) did my rock sliders, D44a rear disc brake swap (stops awesome with 35" mtrs).
I also welded front and rear spiders and added a DIY posilock for the CAD.
So as it sits i am a 95 YJ with approx 5" lift on 35" MTR's 4:10 welded Dana 30/35 combo.
This winter I am planning the Belly Up skid plate and some more armor.
Thanks to all for the support and comments!
PS it took 3 years but the cost was less than $500 total because of trading and selling and buying, would I do it again NO! lol easy to say now, and I have been thinking about selling it to upgrade to a LJ/JK.
Old November 8th, 2012, 01:04 PM   #16
Mr.Green
I can levitate!
Mr.Green's Avatar
I put a 95 Grand Cherokee 4.0 into my 99 TJ that had a 4.0. By the time the motor swap was done, I had to put every single accessory from the original TJ motor on the GC motor (including valve covers, thermostat housing, oil filter) to make it work. Not a single plug, hose, mount, anything would work. CraZy. Never again....
Page generated in 0.36192 seconds with 70 queries
