In Need Of Some Tech Help W/ 460 Bbf - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 17th, 2008, 08:26 PM   #1
TROOPER79
TROOPER79's Avatar
Default In Need Of Some Tech Help W/ 460 Bbf
I Got An Early 70's 460 Bbf And Im Having Trouble With It. The Problem Is It Runs Really Rough (like A Tractor) . Like Its Running Too Lean. Also It Did Run Good When I First Put The Engine In The Truck For A While (until A Buddy Borrowed It)!!! So This Is What I Have Done To It Since, Leak Down Test (both Wet And Not) W/ Good Psi, New Holley Carb(checked That For Adjustment), Spark Plugs Wires ,cap And Rotor, Coil, Brain (truck), Fuel Pump, Fuel Filter, Drained And Refilled Gas, Adjusted Dist. By Sound And By Timing Light , Checked Vac Psi, Adjusted Carb And Dist. Recheck, Recheck..... Now I Think Its The Heads???????? I Need Some Help With This ... I Am About To Just Go And Get This 429 Bbf , But Trying To Fix The 460 Thanks
TROOPER79 is offline   Reply With Quote
Old April 17th, 2008, 08:37 PM   #2
IDIeselman
IDIeselman's Avatar
Wow you pretty much hit on everything. If he over wound it I'd pull the valve covers and check for a broken valve spring next. Or possible a tuliped valve sinking in the seat.
Old April 17th, 2008, 08:50 PM   #3
TROOPER79
TROOPER79's Avatar
Im Going To Get The Heads Worked On This Weekend . Is There Anything Else It Could Be . Just Dont Want To Put Alot Of Money In It , When I Can Get This 429 Great Runner For 1000 Before Someone Else !!!!
Old April 17th, 2008, 09:02 PM   #4
IDIeselman
IDIeselman's Avatar
Have you pulled the dizzy and checked the drive gear? If the cam wasn't put in correctly it may have took out the drive or wiped a lob on the cam. Pull the covers and check all the rockers. $1000 is a little pricey for a stock/fresh 429, Is it built?
Old April 17th, 2008, 09:12 PM   #5
TROOPER79
TROOPER79's Avatar
What Is The Dizzy ?? Are You Talking About The Timing Gears And Chain ?? If That No This Weekend I Will . Fresh Mild 429... Is That High Priced?? Thanks
Old April 17th, 2008, 09:30 PM   #6
IDIeselman
IDIeselman's Avatar
Sorry, Dizzy=Distributor, Yea I would say that's a little high but there are alot of them in my area. Do you know what was done to it and how long ago? There is a fresh BB for sale in the parts section here Cheap.
Old April 17th, 2008, 09:35 PM   #7
TROOPER79
TROOPER79's Avatar
How Do You Check The Drive Gear On The Distributor With It Out?? Never Done That
Old April 17th, 2008, 09:47 PM   #8
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Pull the distributer and check the gear on the bottom. If its broke or missing teeth then you might have some problems. I know my cam has to have a bronze cam gear on it and i have to replace them after a while. It does sound valve related if yoiu have done all the things you say you have. I got a 500 hp 460 ill sell ya but it aint going to be cheap.
Old April 17th, 2008, 09:56 PM   #9
TROOPER79
TROOPER79's Avatar
Ill Check The Distributer Thanks For All The Help . So Its One Doller Per Horse??? Haha What You Looking To Have For It
Old April 17th, 2008, 10:02 PM   #10
Fullsize4life
Kicking Cancers ASS
If yo want send me a pm and well chat
Old April 18th, 2008, 12:09 AM   #11
bronco4-play
Do it like you mean it
bronco4-play's Avatar
Two possibilities for you. I had a 76 460 that would suck the bottom of the intake gaskets in and create an internal vaccuum leak. It would pass any external leak test I did on it. It had the tin valley pan type gasket and after it did that twice over a few years I solved it by using an intake gasket set for a 70 motor (they didn't have the tin pan).
I'm not sure what year ford started using hardened exhaust seats, but my 71 460 had two valves beat themself into the head when leaded gas was no longer available. That caused a john deere tractor type miss but did not show up on the compression test.
Good luck
bronco4-play is offline   Reply With Quote
Old April 18th, 2008, 11:54 AM   #12
mudbillyredneck
mudbillyredneck's Avatar
Good luck
Had a 460 motor do exactly the same thing...with the intake gaskets.......
Except I had more than 2 valves get beat up..
.I actually started calling that truck " Johny "...:tonka:
hope this helps.....Stay away from $1,000 motors...when you can rebuild yours, custom to your needs , for Less !!!
good luck.
mudbillyredneck is offline   Reply With Quote
Page generated in 0.23509 seconds with 59 queries
