Jeep/Chevy Tach Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 13th, 2005, 10:11 PM   #1
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Default Jeep/Chevy Tach Question
Im really wondering how hard it will be to keep the stock tach in the jeep. Someone told me that with the correct resistor inline with the tach signal i could make it work. Anyone know what the resistace from 4 cylinders to 8 would be. Ive got all the gauges nailed down so far except the tach and speedo, which i think i may be able to use an electronic sending unit from a 231 and somehow set it up to work with the cable drive from the NP205.
Thanx Guys
Old November 14th, 2005, 12:39 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I believe you will need a 90 ohm resistor to make the jeep tach work with the chevy distributor. I will try and find that info out.
Old November 14th, 2005, 03:24 PM   #3
BigBlkYJ 355
U-Joints Fear Me
Thanx bill
Old November 16th, 2005, 12:56 PM   #4
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
IIRC the cable drive and electronic/mechanical sender in the NP231 are interchangeable. When you pull them out compare them from the connectors down.
Old November 17th, 2005, 05:30 PM   #5
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
This has nothing to do with the speedo...
Old November 18th, 2005, 04:36 PM   #6
BigBlkYJ 355
U-Joints Fear Me
well i kinda mentioned it in the 1st post, but its not going to be a 231 going back in, and i doubt a 231 sender will bolt to a 205 t-case.
Page generated in 0.20946 seconds with 41 queries
