converter leaking? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2008, 09:12 PM   #1
88mudder
In the band!
Default converter leaking?
I just installed a Ford AOD and ive done this one other time and i always notice fluid leaks from inside the bell , down, and onto the floor. I filled the conerter 1/2 way with it standing up while on the floor. Is this converter leaking? Will it eventually stop after the overfilling is out?
Old April 15th, 2008, 09:35 PM   #2
mudbillyredneck
mudbillyredneck's Avatar
Are you changeing the seals on all these used trannyies ???
Told ya you should of just rebuilt your old one with new parts.....
mudbillyredneck is offline   Reply With Quote
Old April 15th, 2008, 10:12 PM   #3
Bones
Bones's Avatar
sounds like the pump seal. Ideally the snout of the torque converter will sit inside the oil pump, with a series of O-rings preventing leakage.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 15th, 2008, 10:14 PM   #4
bigcountrysg
Countryboy
bigcountrysg's Avatar
Pump seal or the front input seal of the trans is leaking. Unless the shaft of the converter has some damage on it causing it to not seal around the input seal.
bigcountrysg is offline   Reply With Quote
Old April 16th, 2008, 06:18 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
other possibility other then the front seal is the gasket behind the front pump itself. just ran into this problem in a C6 in a lincoln. change both and be done with it.
Page generated in 0.24348 seconds with 38 queries
