need a little help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2008, 07:43 PM   #1
gadgit0
gadgit0's Avatar
Send a message via AIM to gadgit0
Default need a little help
i have a 91 f150 Nite V8 302 4x4 5sp mazda m5 tranny. what i wanted to know is is my tranny shot or is it something else? i was on the way to work and down shifted into 2nd comeing up to the light, the light changed and let out on clutch to continue drive and my truck jerked forward and stalled. after that i started it back up and couldnt move in 1st or 2nd, 3rd, 4th, and 5th would move. so i got to work only a block away. stayed in 3 then to 4th there.. once i got to work i pulled out back and tried all the gears and still 1st and 2nd wouldn't work, now 3rd and 5th wont. and i tried reverse and that didnt work.
any one have an idea what going on?
and second if anyone could tell me what the difference between a mazda m5 tranny and the zf 5sp tranny are other than gearing? someone said that the driveshaft going into the transfer case is the difference.. is this correct?
gadgit0 is offline   Reply With Quote
Old April 14th, 2008, 08:21 PM   #2
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Possibly a broken shift fork or the roll pin that retains the fork to the rail. Sounds like you will need to open up the trans. A ZF is much stronger than a Mazda trans and also much more expensive. If you go with a ZF I think the only thing you have to watch for is that you get the small block version (mated to 351's) the big block version uses a different bolt pattern.
Troll53 is offline   Reply With Quote
Old April 14th, 2008, 09:25 PM   #3
bj house
bj house's Avatar
yeah sounds like you will have to open it up unless it has external linkage like my old 3spd then check that first of course.
Old April 14th, 2008, 09:36 PM   #4
Tom
Because racecar
Tom's Avatar
I'm going with the shift fork as well. It us very common in those.
Old April 14th, 2008, 09:40 PM   #5
gadgit0
gadgit0's Avatar
just popping the top from inside the truck then?? what would be external linkage?
Old April 15th, 2008, 01:21 PM   #6
Troll53
Troll53's Avatar
You might be able to pop the top cover, not sure how much room they give you though. You do not have an external linkage, the Mazdas use hydraulic clutches.
Old April 15th, 2008, 04:55 PM   #7
gadgit0
gadgit0's Avatar
i had to replace the forks last year when i replaced the tranny so my carpeting is already torn inside.. anything in particular i should be looking for when i pop it open? or is it just going to shout out at me that it broke?
Old April 28th, 2008, 07:51 AM   #8
gadgit0
gadgit0's Avatar
i popped the top off and it looks like everything is still connected correctly.. i dont know what else this could be.. the 3/4 fork(i think) looks to be worn very little compared to what it was last year when i replaced the top. any other ideas? i can post some pics if that might help someone help me.
Old April 29th, 2008, 08:03 AM   #9
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
sounds like you have a bad slave cylinder.
Old April 29th, 2008, 05:40 PM   #10
Never_Evil
I just took out my mazda 5spd out our 88 f150 reg cab long box. Shifted great for us, no jamming into gear. Let me know if you are interested. I have the master cyl, internal slave/throw out bearing combo, hose to connect the master to slave and the trans, transfercase, and both sticks so its a complete setup.
Its just dirty because we had a leak rear main on our straight 6.
Old May 2nd, 2008, 12:46 PM   #11
gadgit0
gadgit0's Avatar
pm sent.. i was calling around and a couple tranny places said it might be the input shaft or the syncro assembly
Page generated in 0.33029 seconds with 56 queries
