TTB Alignment - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2008, 01:02 PM   #1
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Default TTB Alignment
Where is the best place to get a TTB aligned in northern Oakland or southern Lapeer county? I've had my Ranger in twice and it still does not drive straight! I need a good, knowledgeable mechanic.
Troll53 is offline   Reply With Quote
Old April 14th, 2008, 01:12 PM   #2
Bones
Bones's Avatar
dealers really aren't all that expensive for things like that.... especially since you already wasted your money twice with people who don't know what they are doing. You could have had it done right once at the dealership for less.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 14th, 2008, 01:45 PM   #3
88mudder
In the band!
is the truck suspension lifted? If its lifted its gonna be tough getting it perfect.
Old April 14th, 2008, 02:04 PM   #4
Troll53
Troll53's Avatar
Truck has stock suspension and has been to the dealership... still makes u-turns on the e-way if you let go of the wheel
Old April 14th, 2008, 02:33 PM   #5
88mudder
In the band!
is all your steering components tight? How about your ball joints? If everything is tight then once the alignment is done it should go straight, unless something is majorly bent. Make sure your tires are balanced too.
Old April 14th, 2008, 02:40 PM   #6
chris1044
chris1044's Avatar
FIRST thing ANY alignment technician (that knows wtf he's doing) should do when aligning a vehicle with a pull issue is check the tires: are they all inflated properly? If so, swap the front two tires and see if the pull follows the tire.....
Any chance you have the print out from the alignment(s)?
Old April 14th, 2008, 02:43 PM   #7
Troll53
Troll53's Avatar
The whole front end was rebuilt around a year ago (ball joints, tie rods, drag link), tires are newer and recently balanced. Both shops tell me the alignment is in spec and front end is tight, still no go. This is not a trail rig it was my dd and sees very little back road driving. I need someone who really knows how the ttb works to figure out what is going on.
Cross rotation of tires has no effect, even swapping out for the tires/wheels on my BII had no effect. Sorry I do not have the alignment specs.
Old April 14th, 2008, 03:51 PM   #8
sucks your so far away, TTB Alignments is my thing. Sure you don't have a dragging caliper or overtightened wheel bearing
Old April 14th, 2008, 08:11 PM   #9
Troll53
Troll53's Avatar
I don't remember seeing any abnormal break wear the last time I pulled the wheels, would a tight bearing cause that much pull? You seriously do not let go of the wheel traveling faster than 40-50 or you will be in the oncoming traffic. I will have to check it out again this weekend. Thanks for all the suggestions guys.
Old April 14th, 2008, 08:35 PM   #10
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
can you bring it to westland?
Old April 14th, 2008, 09:57 PM   #11
88mudder
In the band!
if its pulling that much and the toe is perfect and everything else is tight then something is bent
Old April 15th, 2008, 01:24 PM   #12
Troll53
Troll53's Avatar
Westland is a bit far for me but if push comes to shove, I might just do that. I agree, something has to be tweaked or worn out, just can't seem to find a mechanic who has a clue. This sucks even more because I work in the automotive field and deal with so called "mechanics" all day long...
Old April 15th, 2008, 02:05 PM   #13
mudbillyredneck
mudbillyredneck's Avatar
to check an overtightened wheel bearing...drive a short distance and feel the hub for heat....
sounds like play in the drag link or stupid for steering y shape system
mudbillyredneck is offline   Reply With Quote
Old April 15th, 2008, 07:44 PM   #14
88mudder
In the band!
retorque your wheel bearings
Inner locknut- 30 ft lbs, back off nut 1/4 turn, tighten 16 in lbs (do this procedure while spinning the rotor)
Outer locknut- Tighten to 150 ft lbs
Old April 15th, 2008, 08:21 PM   #15
badazzamc
Get Some
badazzamc's Avatar
why dont you take it back to the dealer and let them do it again, it should be free if it's a come back.
Old April 16th, 2008, 07:25 AM   #16
Troll53
Troll53's Avatar
Because I work for the dealer and here employee = "push it over there in the corner and forget about it."
Old April 16th, 2008, 09:42 PM   #17
EERNGER98
Taco driving jeep wheeler
EERNGER98's Avatar
If thats how they treat your rig, than i would take it to the dealership in the next closest town. it sucks when your stuff gets put on the back burner, i was trying to keep a local guy afloat, but all he wanted to do is tinker with his race car as my truck sat outside (my dd) once you wait over a week for a power steering pump, it makes the deal kinda sour. hope you get to the bottom of your issue.
EERNGER98 is offline   Reply With Quote
Page generated in 0.42072 seconds with 74 queries
