Shop press advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2008, 01:22 PM   #1
amc78cj7
amc78cj7's Avatar
Default Shop press advice
I've decided to buy a press so we can install our own bearings including outer axle shaft bearings for a rear 9" axle. I need advice.
What do you think of this? $200 at harbor freight.
Are there any options I should look for? Thanks.
FREE PAIR OF ARBOR PRESS PLATES WITH PURCHASE!
Remove and install bearings, gears, U-joints, bushings, ball joints, pulleys, etc. Open side heavy duty construction allow work on the longest work pieces. Raise and lower table for the best working distance possible. Spring return ram speed up your work. Get tremendous pressure with very little effort for all your arbor and press out jobs!
Working distance: min: 0" - max 32"
Width between channels: 22-1/4''
Overall dimensions: 60" H x 26" D x 26-1/2'' W
Shipping weight: 200 lbs.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old April 13th, 2008, 01:44 PM   #2
lovemychevy
Something Clever
lovemychevy's Avatar
my neighbor has one that looks the same as that (not sure if its exactly the same or not), i have used it and it works very well, but if i was going to buy one, i would get one that you didnt have to manually pump
lovemychevy is offline   Reply With Quote
Old April 13th, 2008, 01:50 PM   #3
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
I have one of those. It's worked well so far.
They are frequently on sale at HF so I would watch for that and not buy at full price unless you need it right then.
Old April 13th, 2008, 03:49 PM   #4
firehawk
Live Action!
firehawk's Avatar
I have one also. It works.
Old April 13th, 2008, 04:11 PM   #5
dune coon
do work
dune coon's Avatar
make sure when you buy it that the press plates are actually plates. I bought a 30-ton model from a place here in town...once I assembled it and opened up the rest of the packaging, the "press plates" were just 6" structural channel, which I destroyed the first time I used it.
also, an air over hydraulic jack kicks ass, not sure if they have those at HF though??
dune coon is offline   Reply With Quote
Old April 13th, 2008, 04:15 PM   #6
PavementPounder
PavementPounder's Avatar
Who is "we"?
Old April 13th, 2008, 04:40 PM   #7
amc78cj7
amc78cj7's Avatar
Originally Posted by PavementPounder View Post
Who is "we"?
Me and the son. As soon as we're done pressing on the bearings we are going to weld up some cast TRE and hit the road.
Old April 13th, 2008, 04:42 PM   #8
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i dont think its a tall enough press to get axle shafts in and press the bearings on
Old April 13th, 2008, 04:48 PM   #9
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Go to the lab and whip up some concoction which gives you 50-ton press abilities for a minute or two and put 'em on yourself.
Or, run 'em up to the local parts store/machine shop.
Old April 13th, 2008, 05:06 PM   #10
shawn
Resident HVAC/R Jambi
shawn's Avatar
You may be hard pressed (hardy har har) to find a cheap/garage press that will be tall enough for axle shaft bearings, but I may be wrong. So be sure you know the length of those shafts and know the hight of the press "table." Besied that, make sure you ahve the proper tooling to have behind that bearing when pressing it on, otherwise you may end up killing a bearing. Personally, I just heat the bearing up and sliding it on. But the "wedding ring" may not be that easy.
Old April 13th, 2008, 06:11 PM   #11
I have that press, and if you put the bitch all the way down, you can fit jeep sized shafts in there. Don't know how much beyond that it'd do, though.
I have done the rear shafts on my toy rear axle a few times to get my discs installed.
Only issue I've had with it was there's a brace welded at the bottom to keep it from spreading apart. I've cracked those welds pressing some solid stock into DOM, admittedly beyond what the thing probably should have been doing.
You can update later to an air over hydraulic jack when you get sick of pumping.
Page generated in 0.23519 seconds with 55 queries
