SAS options - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2008, 05:07 PM   #1
88mudder
In the band!
Default SAS options
swapping in a SAS to my '84 Ranger. I want front leafsprings and SOA. What axle will work for me? It doesnt have to be a Ford axle, anything will work. I was thinking a waggy d44...i need drivers drop.
Old April 12th, 2008, 11:15 PM   #2
88mudder
In the band!
lets hear it SAS junkies
Old April 12th, 2008, 11:25 PM   #3
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
you can find out a lot of this info on www.therangerstation.com
lepp1892 is online now   Reply With Quote
Old April 12th, 2008, 11:59 PM   #4
88mudder
In the band!
seems like theYJ d30 with leafs will be most trouble free. Id SOA it first and run YJ leaf packs and a couple leafs added in to handle the weight of the v8.
Would high steer be required if SOA conversion is done? Kind of a jeeper question on the Ford tech..:tonka:
Old April 13th, 2008, 11:31 PM   #5
TurdBronco
Your going to swap in a dana 30? Don't you already run 35's?
I have most of a d44 out of an early bronco i can sell ya if you want to go that route. It has the welded on c's that you can cut off and run leaves, or run radius arms with coils.
Old April 13th, 2008, 11:37 PM   #6
88mudder
In the band!
its going under my project 302 ranger, currently on 28" streets ...although it will prolly be on 35's after the axle swap.
How much for the d44? High pinion or low? Does it have highsteer?
Old April 15th, 2008, 12:58 PM   #7
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
when you do soa and dana 30 yes you have to run a high steer
Bronco Ollie is offline   Reply With Quote
Old April 16th, 2008, 07:20 AM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
y not run coils? they ride softer, and will have more flex then a leaf spring. not sure which axle you should use to make it work.
Old April 16th, 2008, 07:36 AM   #9
MrGrey
propane evangelist
MrGrey's Avatar
Not necessarily true....
MrGrey is offline   Reply With Quote
Old April 16th, 2008, 07:42 AM   #10
lepp1892
lepp1892's Avatar
If your gonna go with leaves... I'd say go with Toyota leaves, I've heard a lot about how flex and ride quality are still very good.
Old April 16th, 2008, 07:47 AM   #11
chris1044
chris1044's Avatar
You would be a fool to go through all the work of swapping an axle in and have it be weaker than your current set up (assuming you've already got the D35 in it)- mainly because you are going to have V8 power and weight over the axle.
A wagoneer 44 with leafs would be a good option.....
Old April 16th, 2008, 09:36 AM   #12
88mudder
In the band!
Found an EB d44 out of a '72 , pretty set on it now!
Old April 16th, 2008, 09:37 AM   #13
88mudder
In the band!
thx guys i will change out those seals asap
Old April 16th, 2008, 09:32 PM   #14
DeRanged mudder
completly insane
DeRanged mudder's Avatar
Send a message via Yahoo to DeRanged mudder
The first thing you need to do to the EB 44 is upgrade the axles. The left axle from a 1/2 ton straight axle will fit but the right you will have to buy from Jeff's bronco graveyard.
I'm also interested in why the leaves?
DeRanged mudder is offline   Reply With Quote
Old April 16th, 2008, 10:50 PM   #15
88mudder
In the band!
I changed my mind on that now. Im going to run coils and radius arms. I found a EB D44 out of a '72 that im getting.
Old April 17th, 2008, 12:37 AM   #16
DeRanged mudder
completly insane
Do you have all the mounts and brackets with it? It is basically a bolt in if you do.
Old April 17th, 2008, 12:38 AM   #17
88mudder
In the band!
the axle is still in the bronco so im gonna take everything with it , brackets and all.
Page generated in 0.24165 seconds with 74 queries
