Dana 44 out of dodge ram 1500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2008, 01:07 PM   #1
Projectram
Default Dana 44 out of dodge ram 1500
Hey guys i was wondering if anyof you had the d44 front out of a 2nd gen dodge 1500. If you do let me know and let me know how much you want for it. Or if you know whwre i could find one for cheap that would work too. Thanks
Eli
Projectram is offline   Reply With Quote
Old April 13th, 2008, 01:04 PM   #2
PavementPounder
PavementPounder's Avatar
Bolt this bitch in. (Because it bolts in.)
http://www.greatlakes4x4.com/showthread.php?t=84732
Besides being a hell of a deal pricewise, its a bolt-in upgrade in every way for you. It also gets you away from the pressed-on rotors. This axle has the newer-style brakes.
The rear D70's to match it are pretty common and not terribly expensive, either. Probably half that axle's cost at the most and most of them are 4.10, too.
Old April 13th, 2008, 02:40 PM   #3
Projectram
Thats is a sweet deal but it wont just bolt in for me. I have an 02 with IFS now. The reason i want to go with the d44 is so i dont have to change the rear axle right now as well so i will need to keep the same bolt pattern cause i dont want to use adapters and wont have enough money to buy new wheels and tire right away when i do the swap.
Page generated in 0.19739 seconds with 32 queries
