opinions wanted - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2008, 10:01 PM   #1
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
Default opinions wanted
please dont bash me ok
i need to know what you all think of this.
Old April 11th, 2008, 10:03 PM   #2
FlatFender
Tap Tap Splat
FlatFender's Avatar
im not really sure what happened there, but I just wanted to post in this thread because I like threads where people ask my opinion.
My opinion is that it looks like something steering related.
Old April 11th, 2008, 10:05 PM   #3
04 EDGE
04 EDGE's Avatar
yes it is, is it safe?
Old April 11th, 2008, 10:06 PM   #4
JEEPR
Playing Possum
JEEPR's Avatar
I think it would work fine to get you off the trail if you broke your steering.
JEEPR is offline   Reply With Quote
Old April 11th, 2008, 10:06 PM   #5
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
Definately got a good amount of heat on the welds.
TJontherox is offline   Reply With Quote
Old April 11th, 2008, 10:07 PM   #6
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Maybe as a trail spare.... i wouldn't run it on the street.
Old April 11th, 2008, 10:08 PM   #7
04 EDGE
04 EDGE's Avatar
well this may have to work till more money falls into my pocket.
Old April 11th, 2008, 10:08 PM   #8
xjmichigan
xjmichigan's Avatar
why not just use a single tube?
Old April 11th, 2008, 10:09 PM   #9
04 EDGE
04 EDGE's Avatar
it was free
Old April 11th, 2008, 10:30 PM   #10
Renegade II
Coil springs are for pens
Renegade II's Avatar
MICHIGAN VEHICLE CODE (EXCERPT)
Act 300 of 1949
257.710c Bumpers; height limitations; lift blocks; prohibited modifications; construction of section; applicability; definitions.
Sec. 710c.
Para(4) All steering components shall be geometrically arranged to function as original equipment manufacture. Welded pitman arms, drag links, and tie rods are prohibited.
Not a bash, just an FYI in case this law is enforced in your area.
Old April 11th, 2008, 10:40 PM   #11
04 EDGE
04 EDGE's Avatar
thats what i needed to see. thank you.
now to figure out how to make it work.
someone on another site suggested to weld in the pitman arm then ream it out to the jeep taper.
not sure what to do at this point.
maybe i could ream the jeep end of it out to a ford size and use something ford related that will thread into the sleeve.
Old April 11th, 2008, 10:52 PM   #12
special ed
Pickup Agent
special ed's Avatar
This is getting "techy". What is it that you are trying to do here ?
special ed is offline   Reply With Quote
Old April 11th, 2008, 10:55 PM   #13
PavementPounder
PavementPounder's Avatar
Act 300 of 1949
Sec. 710c.
You bastard. I was speed reading to the end so I could post that.
Whoa, make it work? Are you still considering using that on the street?
Why would you do that when the TRE at the pitman arm is replaceable? Go buy one of the correct size for the pitman arm.
Buy a threaded rod, some nuts, two TRE's of the correct size, and keep this contraption as a trail spare.
Old April 11th, 2008, 11:08 PM   #14
forbyefore
forbyefore's Avatar
just because you can doesn't mean you should
forbyefore is offline   Reply With Quote
Old April 12th, 2008, 07:28 AM   #15
04 EDGE
04 EDGE's Avatar
i am putting a dana 30 in a ranger. trying to adapt the jeep stuff to the ford pitman arm
Old April 12th, 2008, 07:44 AM   #16
Nuggets
I fix stuff!
Nuggets's Avatar
It looks fine. Good penetration on the welds, nice and straight, run it. If you are concerned about running it on the street, don't be. Clean the welds up a bit with a grinder and paint it. If you get stopped by a cop they usually don't know what they are looking for in a modified vehicle. I used to run my V8 4x4 Geo Metro on the street all the time. I've had cops beside me, behind me, etc. without any problems. The key to success is not drive like a retard on the street.
Old April 12th, 2008, 07:57 AM   #17
luvitmyjeep
broken
luvitmyjeep's Avatar
does it fit,work,funtion like it should? it may be frowned on in here but sometimes ya gota da what ya gota do.
luvitmyjeep is offline   Reply With Quote
Old April 12th, 2008, 08:07 AM   #18
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
Originally Posted by Nuggets View Post
It looks fine. Good penetration on the welds, nice and straight, run it. If you are concerned about running it on the street, don't be. Clean the welds up a bit with a grinder and paint it.:miff: If you get stopped by a cop they usually don't know what they are looking for in a modified vehicle.
Nuggets: You missed the point of the law. It wasn't put there to be 'another technicality' you can be ticked for. It was done for safety.
04 EDGE: While I have seen worse, you had most of the parts to do it correctly. I would heed the advice that some have said and use it as a trail spare, which you most likely won't ever need if you have it made correctly. Why not contact one of the fab shops here in S.E. Michigan and have it done right. OR ask around, I'm sure you can negeotiate some help (beer appears to be a legal tender!) from folks here who can fabricate it correctly.
jim-kb8ymf
kb8ymf is offline   Reply With Quote
Old April 12th, 2008, 08:22 AM   #19
Nuggets
I fix stuff!
Nuggets's Avatar
jim-kb8ymf
I appreciate your opinion but I honestly feel it's ok. The law is designed to keep unsafe components/vehicles off the road. If the letter of the law is followed then you would never see another street rod again.
Old April 12th, 2008, 08:41 AM   #20
95geo
newbie
95geo's Avatar
do you even know how thick the tube is in the middle? I'm not positive but I'm pretty sure those TRE's are CAST IRON and when welded to it does not hold unless done by a very seasoned welder with lots of time on their hands.
are the TRE's slipped into the tube at all or just butt welded? it doesnt even look like the paint and dirt was cleaned off the welded area before welding....
Page generated in 0.37824 seconds with 82 queries
