No Brakes!!!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2008, 12:08 PM   #1
roll-bar Bob
roll-bar Bob's Avatar
Unhappy No Brakes!!!!!!
well my old man went out last night and changed the breaks on his F250 ( ABS) he called me after he was all done and said "this dam thing is not stopping right now" I ask if he opened the bleeders befor taking a C-clamp to the calipers and he said NO I FORGOT !!!
did he kill his ABS unit
Old April 11th, 2008, 12:11 PM   #2
cham
Inconsistant at Best.
Ehhh, I'm sure that you'll find out after he bleeds the lines.
cham is offline   Reply With Quote
Old April 11th, 2008, 12:19 PM   #3
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
did he put breaks back on the truck????
bigjay is offline   Reply With Quote
Old April 11th, 2008, 02:01 PM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
If air got into the ABS unit, it needs to be bled with a NGS...Ford Scan Tool. That is the only way to get the air out(of the ABS).
Old April 11th, 2008, 03:36 PM   #5
roll-bar Bob
yes he does have pads on it
no air in the abs unit
he squished brake fluid through the abs unit backwards does that fu$$ things up
Old April 11th, 2008, 03:38 PM   #6
jeepnxj96
jeepnxj96's Avatar
i have never heard of that before btw it is BRAKES
Old April 12th, 2008, 02:39 PM   #7
bigcountrysg
Countryboy
bigcountrysg's Avatar
I doubt he messed up his abs. Besides even with the abs messed up the brakes would still work. They would just lock up instead of anti-locking. I been doing my brakes on my F-250 since I bought it. I never open the bleeder up. Because the abs works by electronics not off the brake fluid.
Bleed the brake system. All four corners start at the one farthest from the master cylinder. This would be the passenger rear. Then do the driver rear, then passenger front, finishing with the driver front.
bigcountrysg is offline   Reply With Quote
Old April 13th, 2008, 11:55 AM   #8
roll-bar Bob
fixed
Old April 13th, 2008, 12:02 PM   #9
xj97sport
atv rider
xj97sport's Avatar
brakeage denied?
Page generated in 0.26820 seconds with 50 queries
