my 4wk old hedder gaskets blew.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2006, 11:19 PM   #1
4x4inAllDay
Dodge Father-Ram Daughter
4x4inAllDay's Avatar
Send a message via AIM to 4x4inAllDay
Default my 4wk old hedder gaskets blew..
thats retarded... all soundin like crap now... jeez... and i did it right too.. torqued them to spec and bought the good gaskets an shit now i gotta redo them darn hedders
4x4inAllDay is offline   Reply With Quote
Old April 4th, 2006, 11:23 PM   #2
Have you checked the header bolts, though?
They have a habit of backing out, even when torqued down, sometimes, after a few days.
I lost a few header gaskets that way.. bolts would back out a bit, flange would start to warp, gasket blew..
Old April 4th, 2006, 11:32 PM   #3
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
that blows
no pun intended
Old April 4th, 2006, 11:38 PM   #4
4x4inAllDay
well i chcked the hedder bolts today after drivin like that for 2 days gettin irritated as all hell.. sure enough they were slightly loose... i thought that was my problem so i tightened them back up and sitll noisey... so upon further inspection i saw the blew out part on each side... shotty shotty
got any suggestions for next time?
Old April 4th, 2006, 11:38 PM   #5
Leanz
Full taste of tender
Leanz's Avatar
Leanz is offline   Reply With Quote
Old April 4th, 2006, 11:54 PM   #6
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
torque them, get it hot, let it cool, check it, wait a day or to and check one more time. that usally works
GMCsonoma94 is offline   Reply With Quote
Old April 7th, 2006, 05:14 PM   #7
4x4inAllDay
Originally Posted by Leanz
that cat looks dead... but good for a laugh!
Old April 7th, 2006, 05:24 PM   #8
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Might be a dumb question, but you did follow the torque pattern right?
Old April 7th, 2006, 06:32 PM   #9
Muttly
Muttly's Avatar
Spend 30 bucks on copper gaskets once, and never look back.
Muttly is offline   Reply With Quote
Old April 7th, 2006, 06:57 PM   #10
Icebreaker88
Icebreaker88's Avatar
I can tell when my header bolt start to back off from the sound. I just retighten them and it quiets down again.
I have also had good luck in the past using the copper type RTV.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old April 7th, 2006, 07:10 PM   #11
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
I've always thrown the paper crap gasket they come with in the trash. I've had good luck with stock gaskets(name brand) and the 2 day check...............Karl
nmeinc is offline   Reply With Quote
Old April 9th, 2006, 08:16 AM   #12
JEEPR
Playing Possum
JEEPR's Avatar
Snug them up by hand,
tighten them up a little following the correct pattern w/ratchet,
tighten them to spec w/torque wrench,
go for a twenty minute drive,
retighten w/torque wrench while engine is still hot,
They might back out some over the next couple days, just re-check them every other day or so until they no longer move.
JEEPR is offline   Reply With Quote
Old April 9th, 2006, 09:32 AM   #13
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
on my CJ I would get cheap "MR Gasket" gaskets, the thicker paper type ones, them I would use 2 on each side. It's the ONLY way I can get more than a thousand miles out of them. Torque, run engine, re-torque.
btw my hedders were cheap so they would warp more than a good set I bet.
toolmantim is offline   Reply With Quote
Old April 9th, 2006, 09:40 AM   #14
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I guess there is a couple way of doing this. the best is to install the header then run it till its in the shape its in now. then remove it and have it ground flat, then reinstall without a gasket and it will be fine. if you have an alluminum head then you are forced to run a gasket as a insulator. good luck
ps, do not run silcone sealant if you are using an O2 sensor, it coat the ellement and junk it out.
Yetti
Old April 9th, 2006, 12:38 PM   #15
boggin-machine
boggin-machine's Avatar
when u get the heades in the box. they should say drive with them for a day or 2 and retighn bolts. or in teh instrucutions it does anyways
Page generated in 0.23086 seconds with 67 queries
