whos got a tig - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2008, 11:43 PM   #1
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Default whos got a tig
who near monroe has a tig? need a quick weld done on my jeep....nothing special just dont want it looking like poo and figure tig would be the best bet......unless u can make a mig look as good as a tig.......
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old April 10th, 2008, 11:44 PM   #2
ddeadserious
ddeadserious's Avatar
I don't have a TIG, but what are you looking to have welded and why wouldn't MIG suffice?
ddeadserious is offline   Reply With Quote
Old April 10th, 2008, 11:48 PM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
If you get your MIG set up right you can get some pretty welds.
Old April 10th, 2008, 11:49 PM   #4
xjmichigan
xjmichigan's Avatar
I can weld it with my stick, but it will look like poop
Old April 10th, 2008, 11:54 PM   #5
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
I tig.
Have 1 at work..what do you have. Alum?? steel?? stainless? I don't have "mucho time" but I can get some time in easy.
about 1/2 hour south of monroe on 75.
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old April 11th, 2008, 10:21 AM   #6
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
what im looking at doing is turning the tire bumper thing on my yj into a cb mount and need a piece of steel welded to it....i just dont want it to look like poop and figured tig would be the best looking and prolly the strongest......i mean it is an 8ft antena
ill see if i can find a pic of what im talking about
Old April 11th, 2008, 10:34 AM   #7
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
what i want to do is on the part just to the right of the tail light on the pass side i want to have a piece of steel welded to the top and bottom of it.....ill prolly already have the steel all cut out and everything and it unbolts so all ill need is someone to weld it for me
Old April 11th, 2008, 10:37 AM   #8
95geo
newbie
95geo's Avatar
no need to TIG that unless you want the practice. any competant (sp?) welder can make a nice clean mig bead that is plenty strong for an antenna.
edit: if you also want to have someone TIG it on then the joints have to be almost perfect.... 1/8" gaps can't happen or you will see it in the weld.
Old April 11th, 2008, 10:38 AM   #9
fsumotorhead
N8KVB
fsumotorhead's Avatar
Why don't you just bolt it on?
I could MIG it for you, just grind it down afterward.
Old April 11th, 2008, 10:52 AM   #10
this reminds me of the current stack-o-dimes thread on PBB....
Old April 11th, 2008, 11:17 AM   #11
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
hey hey....i didn't even think about grinding it down......good call......ill have to get ahold of you once i have the metal cut out
o and did u clean up the garage yet??
???? im confused
Old April 11th, 2008, 11:20 AM   #12
Nuggets
I fix stuff!
Nuggets's Avatar
???? im confused
The stack of dimes thing is about tig welding. A really nice bead will look like a stack of dimes layed on its side and spread out just a but, sorta like dominos that have fallen.
Old April 11th, 2008, 11:25 AM   #13
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
ahhh i c.....i've heard that before....just didn't make the connection
Old April 11th, 2008, 11:34 AM   #14
jeepnxj96
jeepnxj96's Avatar
go to radioshack and get a mirror mount for a semi truck and bolt it on the inside of that bracket on your jeep, you end up not using the clamp piece of the cb mount and it will hold an 8 ft antenna no problem. no welding required, i can send pics of what i am talking about tonite if you want. heck i thinki might even have a bracket you can have.
Old April 11th, 2008, 11:51 AM   #15
95geo
newbie
95geo's Avatar
Old April 11th, 2008, 11:53 AM   #16
jeepnxj96
jeepnxj96's Avatar
Originally Posted by 95geo View Post
who cuts you flanges? looks like they use a laser.
Old April 11th, 2008, 11:58 AM   #17
bigcountrysg
Countryboy
bigcountrysg's Avatar
I would just bolt on a cb antenna mount. Be done with it, but if you want it welded I am about 20 minutes from Monroe.
bigcountrysg is offline   Reply With Quote
Old April 11th, 2008, 12:05 PM   #18
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
im up your way all the time.....i work at willow run and fly my airplanes on willow rd so if i get the steel cut out and fsu isn't home or cant do it for some odd reason ill let ya know
Old April 11th, 2008, 12:16 PM   #19
95geo
newbie
95geo's Avatar
plasma, cleaned up on the disk sander.
Old April 11th, 2008, 12:41 PM   #20
No its a trend to make MIG welds look a certain way, because people see them and think they are better than a continuous bead.
Pics from the pirate thread:
Here's what I was taught to do:
Stacking the dimes:
Page generated in 0.30211 seconds with 83 queries
