Oil Pressure/ Electrical ????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 9th, 2008, 07:47 AM   #1
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
Default Oil Pressure/ Electrical ?????
alright, on my bronco (5.8L) the oil pressure gauge needle sits on the red line by the L when the engine is on. I have driven it ~50 miles with it like that. Shouldn't the motor have seized up by now if i really had no oil pressure?
Also, my motor does not have the oil cooler adapter that goes from the ring above the filter to the water pump. Could that mess up the oil pressure sensor somehow? is there anyway to test the oil pressure?
Bronco351 is offline   Reply With Quote
Old April 9th, 2008, 07:59 AM   #2
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
put on a mechanical oil pressure gauge, the stock ones are not really accurate and tend to get worse as they age
broncobuddha is offline   Reply With Quote
Old April 9th, 2008, 08:05 AM   #3
Bronco351
Powered by Ford
Bronco351's Avatar
That kinda what i was thinking was that the sensor might be shot. Cause if i really had no oil pressure my engine might have already seized up.
Old April 9th, 2008, 08:26 AM   #4
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
The sending unit on the block is only a $5-10 part, easy fix until you can get to a mechanical gage. It would most likely be knocking like heck or siezed by now if it was serious.
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old April 9th, 2008, 08:44 AM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
you would hear lifter tick before anything as oil won't be getting to the top.
buy a mech. gauge from the parts store for around $10.
Old April 9th, 2008, 08:50 AM   #6
Bronco351
Powered by Ford
Bronco351's Avatar
alright.
Approx how long could a motor go with no pressure?
Old April 9th, 2008, 10:32 AM   #7
Cartman
Can't lose with 42s
Cartman's Avatar
Lifters would start tapping like a son of a bitch almost immediately after not having any oil...You WOULD know.
Cartman is offline   Reply With Quote
Old April 9th, 2008, 01:28 PM   #8
broncobuddha
Starting over
if you put on 50 miles and it still runs good you have oil pressure
Old April 10th, 2008, 08:36 AM   #9
Bronco351
Powered by Ford
Bronco351's Avatar
Yesterday it began leaving oil puddles when i parked it, and the engine was making some klunking noises it sounded like.
Old April 10th, 2008, 11:52 AM   #10
caveman
GeoDude
caveman's Avatar
stupid question but is the oil low?
Old April 11th, 2008, 08:16 AM   #11
Bronco351
Powered by Ford
Bronco351's Avatar
Nope, i checked the oil and it was at the correct level.
Old April 11th, 2008, 08:31 AM   #12
magna-007
magna-007's Avatar
Some motors just wont die, no matter what you do. This was at a buddies place last summer. This car was truly running on just water in the crank case and trans. We drove this car that weekend with just water in the trans. Blew a CV shaft and seal so had to keep putting water in every couple minutes. Hooked up the washer fluid bottle full of water and would squirt it right into the trans while driving.
http://www.youtube.com/watch?v=VuEV6YaBI04
http://www.youtube.com/watch?v=tvdc5ceskqM
magna-007 is offline   Reply With Quote
Page generated in 0.31922 seconds with 59 queries
