Bronco spark issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2008, 06:09 PM   #1
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
Default Bronco spark issues
i am having serious issues getting a spark. anyone have any ideas on this stuff?
ChIeFbRoDy is going to post up some details....its pretty much crazy.
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old April 8th, 2008, 06:19 PM   #2
caveman
GeoDude
caveman's Avatar
ignition module.... maybe
Old April 8th, 2008, 07:19 PM   #3
its like getting power to both the positive and negative, or something but then theres ZERO power coming from the center..even when the coil is hard wired to the battery itself. its done this on 3 coils, and 1 is brand new. if anyone knows anything about electric stuff PLEASE HELP!
Old April 8th, 2008, 07:24 PM   #4
Chief Brody
Get off my lawn.
Chief Brody's Avatar
Okay, I'll try best to explain WTF is going on...
The negative wire to the coil has a good ground.
The positive wire to the coil is getting power.
Yet no power is coming out of the coil. Any of them.
This is the hard part to explain. I'll have to jot it down on some paper next time I'm over there.
You can hook up the negative wire to the negative terminal on the coil, and with a test light if shows that it is ground. BUT, when you hook it up to the positive wire, both of them read nothing.
Also, with the coil hooked up to the ground, it had a good ground test. THEN, when you put power onto it, they BOTH test good for ground, but neither for power.
WTF????
I think we're just going to have to rip out most of the wiring and re-do it....
Chief Brody is offline   Reply With Quote
Old April 8th, 2008, 07:27 PM   #5
^^^^is smart
Old April 8th, 2008, 07:33 PM   #6
xj97sport
atv rider
xj97sport's Avatar
dammit brody you can help him but not me
Old April 8th, 2008, 07:48 PM   #7
i feel a wrenchfest coming on...
Old April 8th, 2008, 07:57 PM   #8
xj97sport
atv rider
xj97sport's Avatar
wenchfest ... im in ..... oh wait you said wrench no im out
Old April 8th, 2008, 08:19 PM   #9
no. youre in.
Old April 8th, 2008, 08:22 PM   #10
Chief Brody
Get off my lawn.
He lives right around the corner, and I can't drive. :tonka:
Old April 8th, 2008, 08:54 PM   #11
im narrowing it down... its hard but im trying
Old April 8th, 2008, 09:11 PM   #12
88mudder
In the band!
302 fuel injected ?
Old April 8th, 2008, 09:26 PM   #13
chris1044
chris1044's Avatar
What engine & year???
And, if the coil (primary) has good power and good ground to it, the next thing to check is whether or not its being signaled to fire.....
Old April 8th, 2008, 09:26 PM   #14
302 carbed, with a EFI computer i think, im not too sure.. all the wiring is still there for it
Old April 8th, 2008, 09:27 PM   #15
its a 1979 302 out of a ford LTD
Old April 8th, 2008, 09:28 PM   #16
how would we check if theres a firing signal?
Old April 8th, 2008, 09:33 PM   #17
88mudder
In the band!
get out the test light.
test to see if u got power coming out the coil.
Old April 8th, 2008, 09:33 PM   #18
chris1044
chris1044's Avatar
what????
So, lemme get this straight. It's a 302 that is carbed, but uses a distributorless ignition system (only reason I can see it having a EFI computes, unless some fucking hillbilly converted it back to a carb)
Exactly....if this isn't a go, you need to tell us what kind of ignition system it has - then we can possibly post up what the engine uses to tell the coil to fire (like for EFI engines it uses the crank sensor, etc...)
Old April 8th, 2008, 09:38 PM   #19
its hickrigged, efi converted to carb..its not a TFI coil i can tell you that much, when it comes to this stuff im blind lol, so if anyone can come help me out..
Old April 8th, 2008, 09:39 PM   #20
88mudder
In the band!
im confused already
have to see it in person
Page generated in 0.30325 seconds with 83 queries
