New Product! 1350/1410 U-Joint Girdles - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old April 6th, 2008, 05:21 PM   #1
greatlakeoffroad
Steel Guru
Exclamation New Product! 1350/1410 U-Joint Girdles
These will run you $59.95 per set delivered lower 48 and include low profile hardware. The bolt spacing is 1.800 c-to-c. These are built from steel and are machined w/ a profile so that your degree of flex is not limited by our unit. These are built to replace the flimsy straps on the Dana Spicer style yokes. I had a problem blowing these straps once I upgraded my driveline w/ the Stak and 1350 CV's. After buying several sets of Morosso crap that does not fit anything but their expensive yokes I went this route. The way I saw it you have two choices buy a new $100 u-bolt style yoke (which was not available for my EB D-44) or save yourself $40 and bolt these on. Oh and yes that second picture is of the pinion from my D-44 sheared off. The fuse should be in your driveshaft in case your wondering. However I upgaded to 1/2" wall DOM tube as I was trying to get rid of the weak link. Guess I assume my stub shafts would be the fuse and they were not. Thanks Shawn
www.greatlakeoffroad.com
Shawn4x4@greatlakeoffroad.com
For Quick Order Processing Call Tonya 260-387-1428
greatlakeoffroad is offline   Reply With Quote
Old April 6th, 2008, 05:22 PM   #2
oz97tj
Wasn't this attached?
oz97tj's Avatar
wow, how come nobody came up with anything like this before?
good idea
Old April 22nd, 2008, 01:57 PM   #3
greatlakeoffroad
Steel Guru
Ttt
Thread Tools
Page generated in 0.19560 seconds with 33 queries
