V8 S-10 towing capacity - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 6th, 2008, 09:13 AM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default V8 S-10 towing capacity
what do you think is the max i can tow with my truck? factory rated at 5000 lbs. i need to be able to tow 6000. doable? or dangerous? if it's dangerous is there anything i can do to make it doable? planning on towing a S-10 blazer and then my camaro. taking the blazer to jersey then coming back with my camaro. engines got plenty of power, have heavy duty brakes and cooling system, class 3 reciever hitch. i plan on adding stiffer springs to the rear end from a 1/2 ton cuz mine sag with a 600 lb quad in the bed.
Old April 6th, 2008, 09:58 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Trailer brakes and a weight-distributing hitch.
@clarkstoncracker
Old April 7th, 2008, 11:37 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
that and inspect your frame REAL close maybe box in some sections.. you'll prob want a sway controll with such a short WB vehical
Old April 8th, 2008, 06:18 AM   #4
XXXJ
Desert Rat
XXXJ's Avatar
Dangerous
Old April 8th, 2008, 07:25 AM   #5
Medic8
You call, we haul.
Medic8's Avatar
It's not so much the engine and the cooling that limits your towing ability, it's the frame, rear end, rear suspension, and how heavy the truck is. I can tell you that 6000lbs will probably pull an S10 around like a toy, should you get into a windy area or run into a sway problem.
Now that's not to say that if you take it easy, get a weight distributing hitch, sway control, a trailer with brakes on it, and keep a real close eye on everything that it CAN'T be done... I just wouldn't want to be on the road anywhere near you.
Good luck.
Page generated in 0.14215 seconds with 38 queries
