Towing with a half ton? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 5th, 2008, 07:43 PM   #1
jthomp
jthomp's Avatar
Default Towing with a half ton?
I don't see myself towing my TJ very often but I can get a deal on a 99 Dodge Ram w/extended cab, 2wd. Mileage is good, lots of new parts and a rebuilt trans. The last two owners are relatives, (so I know the trucks' history). What's everyones' experience with this setup for towing, the furthest runs in the near future would be Drummond and the Badland's. Tell what ya know.
thanks
jthomp is offline   Reply With Quote
Old April 5th, 2008, 10:08 PM   #2
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
I tow with half tons all the time. They do just fine if you can load a trailer correctly and have a trailer brake controller. I prefer to tow with diesel, but a half ton will work fine around here.
88yj is offline   Reply With Quote
Old April 7th, 2008, 05:13 AM   #3
jthomp
jthomp's Avatar
anybody else have some thoughts before I buy this truck
Old April 7th, 2008, 05:17 AM   #4
Flexin' XJ
Flexin' XJ's Avatar
That is what I plan on doing with my XJ. My girlfriend wants a C/K truck and most likely won't be 3/4 or 1 ton. Should be fine. Make sure you get an auxillary trans cooler if there isn't already one.
Flexin' XJ is offline   Reply With Quote
Old April 7th, 2008, 05:48 AM   #5
bearlys2005
bearlys2005's Avatar
Well I had a Silverado 1500 and hauled my CJ, I did not like it at all. I had to drive in the tow setting plus had to take it out of overdirve. My mileage was in the toilet as well as the constant down shifting of the trans told me it was working the truck too hard. I would never drive it hard, I would keep it around 60 at best.
I now have a Ford SD 7.3 diesel and it is completely different. I can leave it in OD, my mileage is not effected much plus no or very little down shifting of the trans. The turbo just spools up as you climb the hills. A good example is by Westbranch, the Silverado would labor hard on that hill but the diesel didn't even notice it. Oh yeah with the diesel I can set the cruise at 70 if I want and it just goes down the road. Now from a daily drive perspective I would rather drive the silverado as a daily driver so it just a matter of what you want and how much towing you're going to do.
Goood luck
bearlys2005 is offline   Reply With Quote
Old April 7th, 2008, 06:09 AM   #6
Nuggets
I fix stuff!
Nuggets's Avatar
Goood luck
Great setup but pricey to accuire.
I've towed with 1/2 tons for years, even with straight 6's without a problem. I currently have a 1/2 ton GMC with a 6.2 diesel in it. I can tow a 2000 pound trailer with a 5000 pound truck on it no problem. The 6.2 isn't much of a towing motor but it does what I need it to do. I leave the truck in drive when I tow and I make sure my tonque weight is just right. I currently tow my rig with a 9 liter diesel in a farm truck. Awsome towing, it's like nothing is hooked to the truck but I'm only getting 9 MPG. I am strongly considering pulling my bogger with my pick up to save some fuel money. The bogger trailer combo is very heavy (11k pounds) but I've done it before with the pick up. Pulling this much weight the pick up is not happy at all and downshifts alot but is should be ok on short hauls to local bogs and such.
Old April 7th, 2008, 07:03 AM   #7
I started towing with a half ton with a 5.3. Was underpowered. Went to a 3/4 ton with a 6.0. Towed great but rode rough. Now I'm back to a half ton with a 6.0. Perfect!
Old April 7th, 2008, 07:05 AM   #8
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i used to tow with a half ton all the time you wont have a problem. for the amount you actually tow owning a 3/4 or 1 ton pickup is not a justifiable expense for allot of people. jeeps dont weigh that much at all.
Old April 7th, 2008, 07:11 AM   #9
rargreen
88
rargreen's Avatar
I tow with a 1/2 ton, make sure to use equalizer bars, sway control, trailer brakes, big trans cooler, trans temp. guage, and try to stay under 60mph. You should be fine hauling a Jeep.
rargreen is offline   Reply With Quote
Old April 7th, 2008, 07:16 AM   #10
bearlys2005
Yeah Jim, mine 1500 was also a 5.3 which was great for pulling itself so the same truck would be much better with the 6.0.
Old April 7th, 2008, 07:26 AM   #11
91wrangler
91wrangler's Avatar
Send a message via AIM to 91wrangler
I tow with a 96' gmc 1500 2wd with the 5.7. When I moved up here a couple years ago I hauled the jeep up and it towed excellent. Like has been previously said just make sure you have trailer brakes and don't try to run 70+ all day long. I still use the truck to tow mainly locally with out an issue.
91wrangler is offline   Reply With Quote
Old April 7th, 2008, 07:40 AM   #12
IFS SUCKS
I like trees
IFS SUCKS's Avatar
I tow a 27ft travel trailer with a 96 tahoe it tows fine at 65mph but as much money as ive spent making it tow worthy i could of bought a 3/4 ton by now:tonka:
IFS SUCKS is offline   Reply With Quote
Old April 7th, 2008, 08:26 AM   #13
kickstand
circling the drain
kickstand's Avatar
Yup.
I tow my jeep on the trailer, no equalizer bars, no sway control, no big trans cooler (factory towing package on '07) I do have a temp guage, and I don't get high tranny temps at all. I tow 75-80.
I also tow a 24ft boat fairly often. a 3/4 would be nice, but the cost difference as hoser pointed out doesn't make it justifiable.
I think you will be just fine.
I towed my tj with a 2wd chevy with a 4.3 liter that had 175,000 Miles on it. (back in 2000) and I had no problems, it wasn't fast, but it handled just fine.
Old April 7th, 2008, 08:32 AM   #14
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
towed with half tons up until the current diesel...
everything from a 31ft travel trailer to a 21ft boat to car trailers... you just need to learn to drive with them...
Having towed with a 318 ram 2wd extended cab, towed a 31ft travel trailer... it did fine, definately liked its gas... the big thing with that was accelerate down the hills to have speed up the next... Living in the northeast we have these things called hills
Viperdave is offline   Reply With Quote
Old April 7th, 2008, 08:38 AM   #15
B
NINJA DEALER
B's Avatar
I have a new f150 every sunday the mounds was open last year i towed a friends 79 k5 blazer on 35's at 75mph, i did turn the overdrive off but thats all i did, and it towed it fine, i even had to tow an f250 home on that trailer from the mounds when he blew a head gasket. i wish i had a brake controler with that load, but it pulled fine at 65-70 thats just my .02 (07, 5.4L 3.73 supercrew)
B is offline   Reply With Quote
Old April 7th, 2008, 11:25 AM   #16
caveman
GeoDude
caveman's Avatar
i've borrowed a 2000 gmc 1500 with the 5.3 towing a 77 f100, 78 f150, and a couple of t-birds and i love that truck. i never once thought it lacked power. it's not as good as my diesel power wise or stoping, but that will be my next truck if diesel stays more than gas....
Old April 7th, 2008, 11:29 AM   #17
SBC YJ
Heavy Chevy
SBC YJ's Avatar
I've towed some heavy shit with my K-1500. Electric Brakes are a must...and like said before load it correctly. My buddy has a 1/2 ton dodge 4x4...his trailer has those load levelers and he put a helper spring on too. Hauls his large cj-7 around
SBC YJ is offline   Reply With Quote
Old April 7th, 2008, 11:45 AM   #18
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
06 Dodge Ram 5.7L 3.92s stupid 20s, Electric Brake Controller, Load Equalizer, 20" Enclosed Trailer.. it will pull to about 90-95 before the trailer starts just being a big wind brake.. mileage at 75 is around 10-11 depending on terrain and headwind.. biggest downfall is the trailer's wind resistance.. and honestly its not much better towing in my dads 03.5 3500 DRW Diesel.. could be because his has 3.55s (oh and i forgot .. ive yet to change the oil in my ram .. 17k miles im sure thats not helping my mileage much :D )
my next truck will most likely be an 09 2500 Hemi.. and as many problems as i see friends/acquaintance's having with dodge/gm/ford diesels ill prolly just pass..
nixxerRsixxer is offline   Reply With Quote
Old April 7th, 2008, 03:11 PM   #19
Nuggets
I fix stuff!
Nuggets's Avatar
What problems are the Dodges having? Haven't heard much from that camp.
Old April 7th, 2008, 03:24 PM   #20
nixxerRsixxer
Homewrecker
staying running .. lift pumps.. fuel filters..
i still would rather have a dodge diesel then the rest but its not in my budget and i dont see that great of an advantage..
Page generated in 0.62601 seconds with 83 queries
