fullsize bronco owners help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2008, 09:06 AM   #1
caveman
GeoDude
caveman's Avatar
Default fullsize bronco owners help
i've got a thing for a topless fullsize and i found a guy that wants to trade his rusty 88 with a new trans for my 2wd explorer. but i'm lookin at all the important stuff and it's mainly the driver floor is a rust hole and where the cab corners would be.
he says when the tailgate is down that the side's flex and you have to pull them together to close the gate. is that going to get really bad if the top is removed. basically how much does the top add to the structure.
Old April 4th, 2008, 09:10 AM   #2
masterbeatty
masterbeatty's Avatar
well same problem myne has that means the floor is rotted. and myne the quaters were fallin down around the floor. i would pull the carpet back and see how the rear floor looks, theres a seam that runs from the back to he ledge infront of the back seat check that. also check the core supports by the body mounts infront. those areas rust bad. the core support is easy to fix, so is the floor if you can weld and hve sheet metal around
Old April 4th, 2008, 09:12 AM   #3
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
It would add some structural intergity, i have never heard of having to pull the sides together to close the gate. Just keep the tailgate up when the top is off and that should help.
Bronco351 is offline   Reply With Quote
Old April 4th, 2008, 09:13 AM   #4
76 high boy
serious business
76 high boy's Avatar
yes but if the floor is rotted like said above it will destroy the tailgate. the tailgate will crack on te seams
76 high boy is offline   Reply With Quote
Old April 4th, 2008, 11:44 AM   #5
caveman
GeoDude
caveman's Avatar
another ? Is there any problems with wheeling with the top off?
Old April 4th, 2008, 01:00 PM   #6
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
the body will flex a little more, and it will make the cracks at the end of the rain gutters a little bigger, otherwise no
broncobuddha is offline   Reply With Quote
Old April 4th, 2008, 01:04 PM   #7
blownexploder94
Todd
blownexploder94's Avatar
just pu a rachet strap from side to side so the tailgate doesn't have to take all the stress
Old April 4th, 2008, 02:37 PM   #8
caveman
GeoDude
caveman's Avatar
it looks like an easy fix. the very end of the support rusted off from the 1/4. i'll get some metal and weld it back up. all the body mounts are in great shape.
Old April 19th, 2008, 08:57 PM   #9
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
tell me how to get my rear window down. and i shall help you
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old April 20th, 2008, 12:15 AM   #10
TurdBronco
1 take the access panel off.
2 disconnect the motor plug from the harness, should be yellow and red wires
3 hook up +12 and 0 and you should be good to go
you can also run 2 new wires out to the tailgate from the switch.
or unbolt the motor from the regulator
Old June 26th, 2008, 12:34 PM   #11
bronco91shee
bronco91shee's Avatar
you could just do like i did and break the window......but that was an expensive accident.
effective though......
bronco91shee is offline   Reply With Quote
Old June 26th, 2008, 12:51 PM   #12
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
i wish i can help you but i dont know anything about Bronco's not a thing i tell you..
Rockstar is offline   Reply With Quote
Page generated in 0.29736 seconds with 59 queries
