04 CTD from 6 to 2 cylinders - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 3rd, 2008, 12:07 PM   #1
roll-bar Bob
roll-bar Bob's Avatar
Default 04 CTD from 6 to 2 cylinders
Well it took some work and some research but my big pig is now running on only 2 cylinders now It is slower than snail shit but I get around 96 MPG at 65 MPH I am still working on a way to shut the cylinders down on the fly but for now the testing I have done is looking great
Old April 3rd, 2008, 12:14 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
What did you do, pull the spark plugs?
JohnnyJ is online now   Reply With Quote
Old April 3rd, 2008, 12:16 PM   #3
bj house
bj house's Avatar
o' rly
Old April 3rd, 2008, 12:51 PM   #4
tweak
Are we there yet?
tweak's Avatar
Where did you get the idea / data do to this?
Old April 3rd, 2008, 01:43 PM   #5
KartRacer
Blowd up
KartRacer's Avatar
Old April 3rd, 2008, 04:20 PM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Bob, you missed April Fool's day by a couple.
@clarkstoncracker
Old April 4th, 2008, 06:43 AM   #7
roll-bar Bob
Old April 4th, 2008, 06:46 AM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
I saw them doing that on Top Gear.
Old April 4th, 2008, 06:52 AM   #9
roll-bar Bob
I got a core injection pump from the local junk yard and made some slight mechanical modifications to it.
I am now working with a buddy from college convert it to a electical mod and put it all into a PDA and start market it
Old April 4th, 2008, 06:59 AM   #10
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
make copies of everything and hide them....safe deposit box or something....when the big 5 and OPEC realize that you are trying to market a 3264 miles per tank truck they will swoop in faster than shit!
then if you find it impossible to market it because of the oil companies and the government stepping in, you can just give the mod to your friends (and my friends I mean putting it on the internet and sending it to every news agency that will publish it)
good luck and keep us posted
gotsand? is offline   Reply With Quote
Old April 4th, 2008, 07:00 AM   #11
clarkstoncracker
lol
You better go steal the patent already out there to do this. :tonka:
Old April 4th, 2008, 08:06 AM   #12
KartRacer
Blowd up
KartRacer's Avatar
Is it owned by an exo-caged ZJ owner?
Old April 4th, 2008, 08:28 AM   #13
FlatFender
Tap Tap Splat
FlatFender's Avatar
I only have to add one thing to this thread.
Old April 4th, 2008, 09:19 AM   #14
bj house
bj house's Avatar
Don't most current cylinder deactivation systems open up the exhaust valve as well?
With this setup you are just shutting off fuel to the other 4 right?
Old April 4th, 2008, 09:28 AM   #15
TopHeavy
Yikes!
TopHeavy's Avatar
No. The current MDS (Chrysler) and AFM (GM) systems disable the valves to keep them closed.
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old April 4th, 2008, 12:49 PM   #16
roll-bar Bob
Yes I am still compressing air and throwing it out the exhust but this was better than trying to muffle my turbo my motor is running about 17 percent cooler with pumping the air through it. my EGT has dropped and my turbo is not heating my intake air as much also
Old April 4th, 2008, 12:58 PM   #17
kickstand
circling the drain
kickstand's Avatar
Umm you sure? I was asking Alumcj about this the other day and he said it is purely in the fuel and spark, the camshaft still spinsa nd still causes the valves to open and close like normal.....at least i thought thats what he said. Plus if you were to force the valves closed couldn't you imagine the pressure that would build up with no where to go?
Old April 4th, 2008, 01:00 PM   #18
Flexin' XJ
Flexin' XJ's Avatar
GM uses special lifters that utilize oil pressure to release a pin inside to allow the lifters to not open the valves. The lower portion still moves up and down, but the top does not.
I have had GM training on AFM when I worked at the dealer.
Here is a good link that shows the process:
http://www.gm.com/explore/education/...ngine_dod.html
Flexin' XJ is offline   Reply With Quote
Old April 4th, 2008, 01:03 PM   #19
kickstand
circling the drain
kickstand's Avatar
So where does all of the compression go or how is it released?
Old April 4th, 2008, 01:06 PM   #20
TopHeavy
Yikes!
TopHeavy's Avatar
Are you questioning my knowledge?
"The MDS was part of the engine's original design," said Bob Lee, Vice President Powertrain Product Team, Chrysler Group. "This resulted in a cylinder-deactivation system that is elegantly simple and completely integrated into the engine design. The benefits are fewer parts, maximum reliability and lower cost."
This system should triumph where the Cadillac 4-6-8 failed because of the speed of modern electronic controls, the sophistication of the algorithms controlling the systems, and the use of electronic throttle control. The HEMI will be able to transition from eight cylinders to four in 40 milliseconds (0.04 seconds).
The system deactivates the valve lifters. This keeps the valves in four cylinders closed, and there is no combustion. In addition to stopping combustion, energy is not lost by pumping air through these cylinders.
Fuel economy gains go up to 20 percent under various driving conditions, with a 10 percent (or so) aggregate improvement, without any change in customer experienceódrivers will receive the benefit without changing their driving habits or losing power.
The "trapped air" acts like a spring. Think Fox Air Shocks.
Buy My CJ7
Page generated in 0.42327 seconds with 83 queries
