should I get D35 or D44? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 3rd, 2006, 06:56 PM   #1
MiniJ
MiniJ's Avatar
Default should I get D35 or D44?
I found the perfect '04 TJ Sport except it only has rear D35's, not 44. I plan to off-road some and use it as my DD.
As a newbie, the question I'm wondering is: Is this a deal breaker and should I wait to find one with D44, or would I be ok with only 35's?
Input would be appreciated, and soon!
Thanks.
MiniJ is offline   Reply With Quote
Old April 3rd, 2006, 07:05 PM   #2
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
How big of a tire are u planning on running?
Old April 3rd, 2006, 07:06 PM   #3
jamiesann
jamiesann's Avatar
depends on the price. If you wanted to you could put in a ford 8.8 for around $450 with disk brakes and 4.10 gears.
The ford 8.8 is in many ways superior axles to the d44.
d35 suck but they will hold up to mild wheeling and do just fine as a daily driver of course.
what size tires did you want.
Did you think of buying it with the intention of swapping in an 8.8 if/when you wreck the d35. If you never wreck it your golden and saved money on the 8.8
What ever you do just dont put any more additional money into a D35
jamiesann is offline   Reply With Quote
Old April 3rd, 2006, 07:07 PM   #4
user name
keep your stick onthe ice
user name's Avatar
i prefer to get none modded to start with a little less likely to be prebeat and i think the 44 only came stock on rubicons. as for holding up that depends on how hard on it you are it would be fine on the street and probly light wheeling
Old April 3rd, 2006, 07:18 PM   #5
swampjeep
Swamp Stomper
swampjeep's Avatar
not true, lots of non-rubi TJ's came with D44's in the rear right from the factory
swampjeep is offline   Reply With Quote
Old April 3rd, 2006, 08:00 PM   #6
Noah's Ark
Noah's Ark's Avatar
Thanks.
If you are going to wheel it, find one with the d44. It will save hassle later. There are enough of them out there.
Noah's Ark is offline   Reply With Quote
Old April 3rd, 2006, 09:54 PM   #7
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
when i was looking for my jeep, i only had a few criteria, 4.0, 5 speed, hardtop, full doors, and most importantly to me a dana 44. I got everything i wanted and more
I'm the man in White.
Old April 3rd, 2006, 09:57 PM   #8
PJTJ
PJTJ's Avatar
As long as you don't lock the 35 you will be able to wheel it quite a bit. If its locked bring some extra shafts with you because if you break one it will work its way out of the housing and you would then have a three wheeler....
If you can find one with a 44....buy it!
PJTJ is offline   Reply With Quote
Old April 4th, 2006, 12:15 AM   #9
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Funny...I would be willing to bet that a vast majority of people that crap on the d35 never had any trouble from one that wasn't caused by poor maintenance. Not saying this about the ones that posted in this thread...just in general. I know several people on this board and others that continually say get a d44 or 8.8 and get rid of the d35 and they themselves have a d35 and have had no troubles...locked or not...and up to 35 inch tires.
Now i'll blow an axle shaft going to the grocery store.
Old April 6th, 2006, 02:01 PM   #10
MiniJ
MiniJ's Avatar
Thanks for the advice. I plan on running it stock, at least till I get my feet wet and figure out how to drive the thing. That said, however, I think I'll wait it out and find one with 44's, so I'm not worrying about it while I'm wheeling. And if I ever want to upgrade anything, I'll be all set.
Old April 6th, 2006, 02:12 PM   #11
bigtruckman
One shot, One Kill
bigtruckman's Avatar
I had a 95YJ with a 35 in it and blew it apart (broke both shafts at the splines at the same time) and then upgraded to Moser Alloy axle shafts and never had a problem with it after that. I was running 33x15.50x15 SX's with 4.56 gears and a full detroit locker. Even though i grenaded mine it was still an okay axle for what i done with the Jeep. BTM
bigtruckman is offline   Reply With Quote
Old April 6th, 2006, 02:27 PM   #12
SquirrelWJ
SquirrelWJ's Avatar
Send a message via AIM to SquirrelWJ
god, I wish I could find a D44 for mine... hates my D35. Hates it so much.
Plan on grenading it first before I'm forced to upgrade though. :p
SquirrelWJ is offline   Reply With Quote
Old April 6th, 2006, 02:45 PM   #13
TJrockdogg
Living on the Edge
TJrockdogg's Avatar
like most of the replies stated, it depends on what size tires and how you wheel. the D35 will handle most things without a problem. I used to work at DCX at they test them throughly. but at the same time if you plan on upgrades. I might wait, up to you you can upgrade to a different axle also once you have it. another thing to think about most of the guys giving you the info wheel, so if it already has a D44. unless a newer rubi more than likely it has been wheeled. the D44 is an optional upgrade and as such had that in mind when originally purchased. just my input
TJrockdogg is offline   Reply With Quote
Old April 6th, 2006, 02:51 PM   #14
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Mine was regularly maintained and I blew the ring and pinion going down the highway on stock tires with a 4 banger. -- of course it had 185,000 miles on it,
Though my jeep is the ONLY vehicle of all my familys that has had a rear end blow, my dads suburban is appraoching 300,000 miles, and the vette they sold had 180,000 on it, driven hard. Plus the numerous other vehicles with no rear end problems.
Put in an 8.8 and even with the V-8 no trouble.
Old April 6th, 2006, 04:37 PM   #15
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I would have to say something went wrong...my 35 has 250k on it and it has a locker...ran several sets of 33's through it and now on 35's. This is all hooked to a fuel injected 383. Hell, it still has stock gears. Only thing I ever did to it was put a pinion seal in it after I got fishing line wrapped around the pinion. Change the fluid once...sometimes twice a year.
Page generated in 0.31954 seconds with 68 queries
