Ford f250 lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2008, 08:22 AM   #1
IanSaarinen
89' Model V-TAK
IanSaarinen's Avatar
Default Ford f250 lift
i got a friend who is wanting to lift up his 94 f250 but he isnt sure on what type of lift would be best. hes looking to get at leat 35" tires under it, thanks to any one who can help out
IanSaarinen is offline   Reply With Quote
Old April 2nd, 2008, 08:27 AM   #2
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
http://www.roughcountry.com/ford_4wd_80-98_f250_4.html
bigjay is offline   Reply With Quote
Old April 2nd, 2008, 08:28 AM   #3
masterbeatty
masterbeatty's Avatar
whatever you do dont run blocks.
Old April 2nd, 2008, 08:55 AM   #4
bender
Your daily fullsize fix.
bender's Avatar
Send a message via AIM to bender Send a message via MSN to bender Send a message via Yahoo to bender
i had a 91 F-150 w/ a 4" suspension and 3" body that i had 35's under, and it'd rub wheeling it hard... hitting the rolling bumps at the dunes would scrub the inner fenders when going straight.
i had blocks in the rear and they were fine.
bender is offline   Reply With Quote
Old April 2nd, 2008, 02:13 PM   #5
IanSaarinen
89' Model V-TAK
oh alright, i cant seem to find a nice lift that dont use blocks in the rear, i dont want to use them beacuae i have seen springs s-shaped because if it.
Old April 2nd, 2008, 08:30 PM   #6
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
I have a 4" tough country in my 97 250hd. I like it, with the exception of the front driveshaft rubs once and while on the crossmember. But it clears 35's no problem.
fordlovinfarmer is offline   Reply With Quote
Old April 2nd, 2008, 09:15 PM   #7
masterbeatty
im not sayn dont use a 2 or 3 inch block but try to avoid a 4 or bigger. to many times people run huge blocks and spit them and then oops. personal preferance
Page generated in 0.20805 seconds with 44 queries
