Nuzzy's CJ return to the trail...? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2008, 03:12 AM   #1
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Default Nuzzy's CJ return to the trail...?
Now that our move back to MI is done, it felt like it was time to reexamine the thorn in my side... er... jeep. The jeep was on the verge of becoming a reliable weekend wheeler when Naches struck it down with violent and reckless abandon! Motor mount failure lead to fan destroying radiator while climbing the snag at Funny Rocks thus causing a MAJOR overheat whilst getting towed back to camp. The jeep died as I rolled into camp and then onto the trailer and would not restart once back at home. Since that fateful day last July the jeep has not run, instead sitting useless like the red headed stepchild it has grown to be.
Now I've been having many thoughts lately about the future of the jeep... I've been assuming the motor is toast, I know the frame has cracks, there are still gremlins to be discovered. So what to do...? I want to get back out wheeling so one thought was to simply replace the 258 since everything else I already have would bolt up and get back out there. Then there's the thought of why not upgrade motor and trans if I'm spending money any way. Of course that leads to far more downtime. Then there's the thought... why not just save the hemoraging and buy a used buggy frame keeping my good parts of the jeep.
In the end, all I really want is be on the trail as soon as possible. So I ventured into the garage tonight to begin rediscovering my lovely jeep.
First out was the rad. Does anyone want a gently used delux CJ radiator?
How about a modified industrial application flexalite fan?
Got the headlight/turn signal wiring harness out of the way and thought to myself how it'd prolly be easier to punt the fucker and just wire in a couple of Hellas. We'll see...
She looks a lil nekkid
Then I started getting a good look at stuff. Does this kink looking dealy bother anyone else or am I making stuff up? (please disregard the duct tape fixing a possible vacuum leak)
Ah yes, the almighty CJ frame
Then again, the body wasn't much better. Should probably go ahead and get the cage tied into the frame sooner rather than later.
Now for the fun part. I tried turning the motor over by ratchet to see if it was seized and to my happy surprise, found it to turn over. So then out of morbid curiosity, I took out my battery which I knew to be beyond dead and hooked the cables up to the lovely LS1 sitting in the next stall
And for the surprise of the night, the damn thing sounded like it wanted to fire. At this point, I turned on the propane and began cranking with weif's car running. I'd crank and crank and as soon as I'd let off, I'd hear the motor caugh sputter and die. Over and over it'd do that until finally with some persuasion of the throttle pedal, it fired to life and ran. I got some smoke out the exhaust which I was trying to decipher if it was do to coolant in the oil or just normal condensation from sitting. It didn't smell overly sweet like coolant, but I was so stoked to see life, I may have been overlooking the obvious. In any case, the damn thing didn't sound half bad... No obvious clicks or knocks that I could hear. Now this may just be a temporary moment of jubilation and I will soon be smashed back down to the cruel world of reality, but it is possible this particular 258 is of supernatural ability and on par with the illustrious 22re
I took a video which sucks horribly, but at least the sound is good:
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
After running for a minute or so (shut down before it could get too hot), I noticed this cute little puddle of oil which could either be normal for my plastic valve cover, or could be due to slight warping from the overheating event. I'm not sure which.
So where to go from here? Did I seriously luck out and what ever problem just solved itself? Was it something as stupid as a dead battery not allowing the motor to fire and run? Do I just need to replace the fan, radiator, and motor/tranny mounts to get back on the trail??? I sure as hell hope so but time will tell I guess...
Stay tuned for the comedy or errors that is my jeep
Nuzzy is offline   Reply With Quote
Old April 1st, 2008, 03:27 AM   #2
boggin-machine
boggin-machine's Avatar
could there have been a short or broken cell in th battery that would let it crank.im sure before this that you have tried to jump it with the battery in place.the motor sounds very good as you stated above. i also would cut the wiring and wire in some after market lights. do you plan on driving this machine around much on the road?
Old April 1st, 2008, 04:55 AM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
since my knowlage is more chevy based I would still suspect a head issue. its not like cast iron to grow shut. I have done hundreds of the old straight 6 chevys and the heads cracked. its their nature. I recomend pulling the head and having it checked for cracks. if none are found then I would put in a new head gasket and call it good.
its lttle effort now to repair then out in the trail.
secondly the tube chassie would be a huge step up as would and ELECTRIC fan. to take care of cooling.
Yetti
Old April 1st, 2008, 07:32 AM   #4
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Your Irok is mounted backwards :tonka:
JcrOffroad.com
Like us on Faceook!
Old April 1st, 2008, 07:55 AM   #5
4x Fanatic
Guiness Test Pilot
4x Fanatic's Avatar
Ouch! That hurt. Nice frame damage. See ya out there in a few months... hopefully.
4x Fanatic is offline   Reply With Quote
Old April 1st, 2008, 07:58 AM   #6
Paul04TJ
Small, but talented
Paul04TJ's Avatar
More video's of the wife!
Paul04TJ is offline   Reply With Quote
Old April 1st, 2008, 11:27 AM   #7
Nuzzy
Nuzzy's Avatar
I'm gonna test the bat and alternator. Back when the MM failed, the motor smashed my alternator a couple times on the frame rail so it could've internally effed it. Might just be chasing that since it fired fine once it was completely hooked to a different vehicle's juice. Yeah, I don't need all those lights involved in the harness as this thing is 100% trailer queen, so I prolly will just simplify it.
True true. The tube chassis will come, but I'd rather limit my downtime so I'll have that all ready to go and paid for before I make the switch. I'll be getting a Spal electric fan when the times comes.
I chunked the hell out of the front edges. Figured I'd attack the rear edges for a while Then again, there's no rocks out here to chunk anything on...
Old April 1st, 2008, 11:28 AM   #8
Nuzzy
Nuzzy's Avatar
I'm not married.. She just pretends we are...
Old April 1st, 2008, 11:33 AM   #9
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
sell it....:tonka:
bigjay is offline   Reply With Quote
Old April 1st, 2008, 11:35 AM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
When are we going wheeling?
JcrOffroad
Zoom Zoom!
Old April 1st, 2008, 11:38 AM   #11
brimy311
brimy311's Avatar
How long do those two propane tanks last you? I can get 1.5 days on one tank with my yota 4cyl.
JcrOffroad.com
Like us on Faceook!
Old April 1st, 2008, 11:53 AM   #12
Nuzzy
Nuzzy's Avatar
If all I have to do is fan/rad/motor mounts, then hopefully damn soon. Is there ANYTHING local that even resembles wheelin to test it before I trailer it 500miles to have it break...?
Don't exactly know as I really haven't ran one out. I've always switched out the tank I was using the previous day the next morning since I have 4 of them. With my setup I've been able to go for a day of trail running without tapping into the 2nd one.
Old April 1st, 2008, 12:01 PM   #13
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
badlands is 3 hours from us... can be a pretty good time..
nixxerRsixxer is offline   Reply With Quote
Old April 1st, 2008, 12:05 PM   #14
bigjay
bigjay's Avatar
u can screw around over here in teh allegan area or over in yankee spring....nothing real hardcore tho
Old April 1st, 2008, 12:19 PM   #15
Nuzzy
Nuzzy's Avatar
Where in Allegan?
Old April 1st, 2008, 12:20 PM   #16
Nuzzy
Nuzzy's Avatar
I definitely want to get there just to check it out
Old April 3rd, 2008, 10:14 PM   #17
brimy311
brimy311's Avatar
Your avator looks like sh!t.
JcrOffroad.com
Like us on Faceook!
Old April 3rd, 2008, 10:44 PM   #18
Nuzzy
Nuzzy's Avatar
Festively decorated sh!t...? or just pooped off the front bumper of the jeep in the middle of the trail sh!t...?
Old April 3rd, 2008, 11:25 PM   #19
FlatFender
Tap Tap Splat
FlatFender's Avatar
<------ better shitty avatar.
Old April 4th, 2008, 10:37 AM   #20
Nuzzy
Nuzzy's Avatar
effing classic.
Page generated in 0.46000 seconds with 83 queries
