97? ford dana 60 nuckles ball joint - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 31st, 2008, 09:52 AM   #1
snocross2xtremes
snocross2xtremes's Avatar
Default 97? ford dana 60 nuckles ball joint
lookin for the right ones to convert my dodge 60 from unit bearings to normal tapperd wheel bearings
Old March 31st, 2008, 09:59 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
93ish to 96 are also ball joint but use a cast mount for the big ford caliper. 96ish to 97 use a bolt on bracket for the caliper. If you don't mind using the Ford brakes you can use 93-97
Old March 31st, 2008, 01:11 PM   #3
snocross2xtremes
kk thanks so the 97 will my dodge calipers work is that what ur saying?
Old March 31st, 2008, 01:13 PM   #4
Jeepaholic
Jeepaholic's Avatar
I don't know, I would do some searching on pavementsucks
Old March 31st, 2008, 01:34 PM   #5
PavementPounder
PavementPounder's Avatar
He didn't say anything about your Dodge calipers.
The dual-piston Ford brakes would be an upgrade.
Old March 31st, 2008, 07:05 PM   #6
PavementPounder
These are the ones I had. I was told they were 1995.
Old April 2nd, 2008, 02:57 PM   #7
snocross2xtremes
ttt
Old April 4th, 2008, 09:46 AM   #8
snocross2xtremes
ttt
Old April 5th, 2008, 10:57 AM   #9
snocross2xtremes
ttt
Old April 9th, 2008, 11:05 AM   #10
snocross2xtremes
ttt
Page generated in 0.16298 seconds with 53 queries
