2 stroke Cylinder/Power valve assembly - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2008, 04:39 PM   #1
chris1044
chris1044's Avatar
Default 2 stroke Cylinder/Power valve assembly
Hopefully this gets a reply quickly...
When assembling the power valve(s) on a 2 stroke cylinder, do you assemble it with a lubricant like EOS, or simply use oil, or do you leave them dry and assume the A/F mixture will lube them?
For the most part, when I pulled the jug apart it was quite sludged up and smelled of nothing other than Klotz (which smells delicious, btw )....so, I assume it does get lubed by the A/F mixture, but I can't really see it being assembled 'dry'
Old March 28th, 2008, 08:17 PM   #2
Smiley23
Smiley23's Avatar
I dont see why not. I dont think it will hurt to apply some light lubricant like wd40 if you think it needs it.
Like you said, the A/F mixture will lube them real fast.
Smiley23 is offline   Reply With Quote
Old March 29th, 2008, 12:39 PM   #3
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
I always just used whatever 2-stroke oil I ran in the motor to assemble it.. normally maxima 927
Old March 29th, 2008, 01:23 PM   #4
chris1044
chris1044's Avatar
Thats exactly what I did....don't think I'll have a problem with it
Old March 29th, 2008, 08:43 PM   #5
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
a little late but anywho...you can put grease on it if you wanted to otherwise wd-40 or 2cycle oil will do fine as well....you just need something on there just don't put it together dry..
Page generated in 0.20774 seconds with 38 queries
