MJ,XJ,gave up YJ,failed BDMT, back to MJ!! - Page 75 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 4th, 2012, 11:36 PM   #1481
Krouoffroad
that'll happen
Krouoffroad's Avatar
I have to finsih up some non truck related projects around the home front (thanks for the trailer stuff) and then I start On-call friday until the following friday. so i'll be down and out until the following weekend. however after that i should be ready to wheel so long as I can source a couple driveshafts before then.
Hopefully this storm dont put too much of a hamper on your timeline.
Krouoffroad is offline   Reply With Quote
Old September 5th, 2012, 01:05 AM   #1482
XJcoupe
1ton XJ
XJcoupe's Avatar
Originally Posted by MiNi Beast View Post
What do you mean by that?
are those arrows on the pockets pointing to something special !
get your passport shit done, come to Canada
Old September 5th, 2012, 06:07 PM   #1483
MiNi Beast
MiNi Beast's Avatar
pointing to the sweet spot.
Yeah raining like hell today but now all sunny, but have to go pick up some wood for a deck I have to build for buddy. Then got called back to work for Thursday and Friday most likely so not going to have my dedicated time that I though I would have but I still say be running this weekend.
Old September 6th, 2012, 04:58 PM   #1484
drew91xj
drew91xj's Avatar
u goona make it to r&v the 28-30 got about 10 + ppl going as of now?
Old September 6th, 2012, 05:20 PM   #1485
MiNi Beast
MiNi Beast's Avatar
Possibly as we have to head down state to swap out rides. Getting rid of durango for a 2000 xj and 93ish old style half ton dodge pickup[tow rig]. Not sure yet but would like to take the new drivetrain out for a good break in. Still have the fortys yet as well. Which brings up me needing a steering box brace, know anyone that has one?
Old September 24th, 2012, 02:01 PM   #1486
MiNi Beast
MiNi Beast's Avatar
up all night soldering wires to make a plug and play harness between the XJ HO dash harness and the MJ renix body harness. We should be good to go. so back to jeep to paint engine bay weld up steering box area on frame, reinforce and start installing engine wiring then enigne by tomorrow night hopefully.
Old September 24th, 2012, 04:04 PM   #1487
choppergar
choppergar's Avatar
Sounds like your making good head way. Your the man!! Best of luck.
choppergar is offline   Reply With Quote
Old September 26th, 2012, 12:50 AM   #1488
MiNi Beast
MiNi Beast's Avatar
Default Beginning of 95 XJ H.O. install in the 89 MJ.
Got a good woman if she'll let you do jeep wiring in bed.
I think I understand wiring alot better now. Had help with harness from this link... XJ dash harness to rear MJ harness wiring
So got the dash in and heater, So worked on the steering wheel as in 95 they use a better steering column so the mounting is different vs the later 89 MJ column.
this was the 95 XJ mount notice smaller mounting bolts as well as it is an inch closer to the fire wall. So you can drill out all the spot welds and weld it back on you firewall easy enough, or just weld on new bracket on the column as the 95 XJ column has all the electronics by the wheel and wires run external of the column not internal like the 89 MJ.
buddy making the welding look easy.
mounted and make it look good.
got the carpet in and center console, little trim work left then seats.
So then got the steering box frame section reinforced up a bit and have a steering box brace on its way and will be getting a JCR Offroad steering box inner spacer just cause I dont feel like making one of those up. So after getting that welded up the woman went to town and painted the engine bay with some rust stopper paint and I will go over everything again with some black paint.
and this bottom part will be the start of a box skid like you see on a YJ/TJ.
So tomorrow check list is degrease engine and trans and change remain seal and valvecover gasket, then need to replace the headed as it has been welded once and is majorly cracked again so need to just replace it for decent on to hold me over till I hit the lottery and get me a borla setup. ;) and then hopefully get the brackets switched out on the seat and get them installed. Then should have engine harness installed in engine bay as well.
Old September 26th, 2012, 01:35 PM   #1489
wakeboard76
wakeboard76's Avatar
Looking good man, what are you going to do when you go wheeling and nothing on your rig breaks? And how am I going to find you on the trails without that blue cloud of smoke following you everywhere?
wakeboard76 is online now   Reply With Quote
Old September 26th, 2012, 09:35 PM   #1490
MiNi Beast
MiNi Beast's Avatar
cause if I dont break I will be able to keep leading you around all day and get at you on the CB! -over- big 10-4!
wiring in and column to gear box is in, engine pulled ready to clean up and replace leaky seals. then swap on replacement header.
Old September 27th, 2012, 11:11 PM   #1491
MiNi Beast
MiNi Beast's Avatar
well ran into some issues with header and intake removal, so in light of it going to do some preventive maintenance and just have the head fluxed and machined. Cleaned up a little today and got some stuff out of the way. so to machine shop tomorrow and get back next week so now being as I have some time going to swap seat brackets and get seats in and cab buttoned up. DO remain seal and auto trans filter. and steering brace came in so install that as well.
rig got some sunshine today. getting close oh so close!
tcase back on and ready to drop in tomorrow.
rugged ridge brace
Old September 28th, 2012, 06:47 AM   #1492
curbdog17
Mini Van
curbdog17's Avatar
What the corn for?
Old September 28th, 2012, 07:03 AM   #1493
kmanxj5011
kmanxj5011's Avatar
Originally Posted by curbdog17 View Post
What the corn for?
kmanxj5011 is offline   Reply With Quote
Old September 28th, 2012, 08:47 AM   #1494
MiNi Beast
MiNi Beast's Avatar
so I can make up some popcorn for my co-driver out on the trail. Got keep them happy.
Old September 28th, 2012, 01:15 PM   #1495
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Mmmmm, popcorn.
That interior is looking mighty nice.
RIP FULLSIZE4LIFE
Old September 28th, 2012, 01:33 PM   #1496
kmanxj5011
kmanxj5011's Avatar
SHOTGUN!!!!!
Old September 28th, 2012, 07:19 PM   #1497
MiNi Beast
MiNi Beast's Avatar
BoB! Bring your Own Butter!
Old September 30th, 2012, 02:58 AM   #1498
MiNi Beast
MiNi Beast's Avatar
got a little more down today. down to the little shit and swapping the seats.
Old September 30th, 2012, 09:16 PM   #1499
MiNi Beast
MiNi Beast's Avatar
She fired right up Alive again with a new breath of air!
Old October 1st, 2012, 08:12 PM   #1500
MiNi Beast
MiNi Beast's Avatar
New shoes for the rig.
Tags
beyond wt, forgotwhathwasbuilding, homorific!, mj>responsibilities, onceathiefalwaysathief, so wt, spenttoomuchonseats, wantstobejustlikedaddy
Page generated in 0.84558 seconds with 84 queries
