MJ,XJ,gave up YJ,failed BDMT, back to MJ!! - Page 60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2011, 11:19 AM   #1181
shortiron
Not bad for a little Jeep
shortiron is offline   Reply With Quote
Old May 1st, 2011, 12:41 PM   #1182
MiNi Beast
MiNi Beast's Avatar
yea yeah, what she said as well.
I'm I bringing them seats over today?
Old May 1st, 2011, 01:07 PM   #1183
shortiron
You can if you want
Old May 1st, 2011, 08:52 PM   #1184
MiNi Beast
MiNi Beast's Avatar
got some better pics today.
Work on the seat install. Passenger seat is in. Drivers needs some finesse to fit around the tcase hump.
So needs little bit more welding done on it and the muffler welded on and the front shock mounts. then be brought back home where I'll finish up the brakes, driveshaft, and then the test drive.
Old May 1st, 2011, 08:58 PM   #1185
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Looking good. Axle width (front & rear)?
Craig
Old May 1st, 2011, 09:05 PM   #1186
MiNi Beast
MiNi Beast's Avatar
Craig
idk, full width with H2's that have 5.25bs I'll measure it next time i'm out. but you can see that they do not stick out any further then with my stock axles and 33's on 3.75bs
Old May 2nd, 2011, 06:44 PM   #1187
MiNi Beast
MiNi Beast's Avatar
ok so found that my tie rods hit on my wheels so will have to run a 1/4" spacer up front no biggie. So measured out the tie rod, 45 1/2 and 21 for the drag link. In that range anyways. And so should be having it tap tomorrow by Sandvipr as I will be mounting is 42's up with his new pvc inserts. Sweetness! Also picked up some nice new tail lights thanks to Dune Coon. So looking to have some corner guards made up by Shortiron and drop those into it, be like the YJ rear corner guards. Be very nice.
Had to cut off the front hole on hy arm to clear rim...
now have to add 1/4" spacer to clear the tie rod end, but then should have no issues running the crossover set up. With my drop pitman arm my drag link will be almost parallel with the tie rod which is good I think, lol
the new tails...
Old May 2nd, 2011, 09:02 PM   #1188
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Nice hack job on the high steer arm..........lol
Old May 2nd, 2011, 09:04 PM   #1189
MiNi Beast
MiNi Beast's Avatar
yeah nothing a 7" grinder can't handle, I have to get me a 7" grinder, makes quick work of things.
You have a chance to check on them shafts?
Old May 2nd, 2011, 09:08 PM   #1190
Fullsize4life
Kicking Cancers ASS
Wednesday probably.
Old May 2nd, 2011, 10:17 PM   #1191
shortiron
not used to 7''s
Old May 3rd, 2011, 05:46 AM   #1192
MiNi Beast
MiNi Beast's Avatar
not used to 7''s
nope just your 4"
Old May 3rd, 2011, 06:44 AM   #1193
drew91xj
drew91xj's Avatar
looks good now find me the rear springs i need so i can try and catch up
Old May 3rd, 2011, 07:53 AM   #1194
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Hey Mini,
Where is the best place to get one of those hi-steer arms?
thanks
RIP FULLSIZE4LIFE
Old May 3rd, 2011, 02:37 PM   #1195
MiNi Beast
MiNi Beast's Avatar
Originally Posted by SHARPMACHINE View Post
Hey Mini,
thanks
I had mine made from a local guy, took about 3 months, but I was in no rush during the winter. Other wise I just look at Ballistic Fabrication or something. But I would think you could just make em up yourself.
Old May 3rd, 2011, 02:40 PM   #1196
MiNi Beast
MiNi Beast's Avatar
Well steering links off to A&B Machine shop, dealt with them before, great guys there. So hope to have them back by weekend.
Also I guess my rear corner guards for the new tail lights is being made up as well so looks like those be on soon as well. which this was my inspiration as some may recognize this jeep off of Comanche Club, as H3RESQ new rig...
Old May 3rd, 2011, 03:06 PM   #1197
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Dude- that thing will look sick with those corner gaurds on there.
Sharp- Mad 4x4 has the best deals that I've found on them. You can get both sides and the hardware for a decent rate. I used them on my last build and they worked very well.
Old May 3rd, 2011, 03:09 PM   #1198
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
All that is real nice, the real question is...
When are you going to buy a motor that doesn't burn/blow through 40 gallons of oil per mile?
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old May 3rd, 2011, 03:12 PM   #1199
MiNi Beast
MiNi Beast's Avatar
when the axles are done, then the focus will be on the engine and drivetain.
Just like daddy taught me.
Old May 3rd, 2011, 03:14 PM   #1200
MiNi Beast
MiNi Beast's Avatar
mine won't come that far forward, and will have 1.5" tube ran at the bottom and braced off the frame. I hate that this MJ is a long bed, my last one was a short bed and is noticeably different out on the trails as one or two tress can tell you
Tags
beyond wt, forgotwhathwasbuilding, homorific!, mj>responsibilities, onceathiefalwaysathief, so wt, spenttoomuchonseats, wantstobejustlikedaddy
Page generated in 0.52254 seconds with 84 queries
