dually to SRW? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 27th, 2008, 08:00 PM   #1
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
Default dually to SRW?
hey what do you need to do to switch to a single rear wheel on a 1990 f-350?, a friend of mine has one and does nt use it, needs a rear main seal, clutch, and probabley new tires, but i can get it fairly cheap, and it has low miles, anyway the duals would be way overkill for towing my 18' car hauler, what would i need to do to run single rear wheels instead? keeping in mind safety is #1, thanks!
broncobuddha is offline   Reply With Quote
Old March 27th, 2008, 08:40 PM   #2
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Nice pooch.
I would say get a new bed and axle and bolt it in.
Old March 27th, 2008, 10:06 PM   #3
broncobuddha
Starting over
just a big flatbed on it for a bed, so thats no problem, thanks thats my pug and boston terrier jezabel
Old March 28th, 2008, 09:04 AM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
Is it 4x4? If not you can swap the rear axle, or just the rear hubs and drums and axle shafts
Old March 28th, 2008, 09:08 AM   #5
broncobuddha
Starting over
its 2wd, thanks, thats what i was wondering if swapping the whole rear end was necessary
Old June 26th, 2008, 01:40 PM   #6
bronco91shee
bronco91shee's Avatar
call me stupid, but i believe they are both fullfloaters and the only issue was longer studs-axle wise...but i could be wrong.
thats all i member from working on them. it seems like you could just thro single wheels on and go. much easier swap then going from single to duallies. then i would do a whole axle swap just to be safe
bronco91shee is offline   Reply With Quote
Old June 26th, 2008, 01:46 PM   #7
PavementPounder
PavementPounder's Avatar
If safety is #1, why is pulling a 18-footer with a SRW your preference? You're saying that a dually rear is overkill, but overkill how? You'd actually be reducing your hauling/towing capacity along with your stability. What is it that you are seeing as bad or undesireable about the vehicle?
Old June 26th, 2008, 02:03 PM   #8
Bishop
Bishop's Avatar
i was thinking the same thing. Possibly save on gas?? or save the next time you buy tires?
thats the only 2 benifits i can see
Old June 26th, 2008, 03:16 PM   #9
beejers
always building
beejers's Avatar
i have a 1990 f-350 single rear wheel that is in the part-out section.
beejers is offline   Reply With Quote
Page generated in 0.17542 seconds with 50 queries
