What gears you need and How much will my speedo be off. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 27th, 2008, 06:21 PM   #1
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Default What gears you need and How much will my speedo be off.
Gear Ratio
(RPM x Tire Diameter) / (Diff Ratio x Trans Ratio x Transf Case Ratio x 336) = MPH
Crawl Ratio
Trans Ratio x Transf Case Ratio x Axle ratio = Crawl Ratio
P-Metric to Inch Diameter
[(Section Width x Aspect Ratio x 2) / 25.4)] + Rim Diameter = Tire Diameter
Ex 235/75R15
[(235 x 0.75 x 2) / 25.4)] + 15 = 28.87"
Tire Change (Find a new Gear ratio)
(New Tire Dia / Old Tire Dia) x Old Axle Ratio = New Gear Ratio
Speedometer Adjuster (With Oversize Tires)
(New Tire Diameter / Old Tire Diameter) x Speedometer MPH = Actual MPH
Another Great Gear Ratio Calculator
The below table can be used to get a rough idea on gear ratios. The colors represent ideal RPM's at highway speeds (65). For highway cruising and best fuel economy stay towards the yellow (2600 rpm), around town daily driving is color coded green (2800 rpm), and for better towing power or just more 4-low power use the ratios near the red (3100 rpm). These calculations are assuming a manual transmission with a 1:1 ratio. If you drive an automatic your RPMs will be slightly higher, and the opposite is true if you have overdrive (your RPMs will be slightly lower).
Chart and info from Mark I. Medina www.4Lo.com
Old December 28th, 2010, 10:35 PM   #2
gotmudd1992
gotmudd1992's Avatar
Send a message via Yahoo to gotmudd1992
my question is if you re gear the rear axles do you also need to do the front as well im have 4.10s in the rear of my 4 cylinder yj and im going to a 4.88 because of the 33 inch tires so should i do the front also
gotmudd1992 is offline   Reply With Quote
Old January 21st, 2011, 12:11 PM   #3
dragtruk
Questionable..
dragtruk's Avatar
Send a message via AIM to dragtruk
i hope you are joking.
dragtruk is offline   Reply With Quote
Old January 21st, 2011, 12:34 PM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
you should beable to get away with just doing the left side (driver) and it will work great
H.o.r.e
Old December 11th, 2011, 02:00 AM   #5
crazygrady127
crazygrady127's Avatar
Well your right about the numbers changing with an automatic and overdrive , I have an 09 JK with 513's with 37" tires and at 70 mph Im cruising at 2400 2500 rpm with plenty of power , but when I turn off the overdrive it sky rockets to 3200 3300 !! Thank god for that over drive !! And in low gear (4-1 Rubicon transfer) I have more power than I need !!
Tear It Up - Fix It - And Do It Again
crazygrady127 is offline   Reply With Quote
Old December 11th, 2011, 09:27 AM   #6
shawn
Resident HVAC/R Jambi
shawn's Avatar
In my 06 LJ with an auto, I went 4.56's with 33's for a couple years. It seemed about right for the road but I really needed 4.88's for the trail. Now that I've moved to 35's, the 4.56's are not cutting it. Really wished I went to 4.88's (5.13 would have been better but that's just way too small of a pinion in a D30).
But my other problem on the trail is that I'm running a 4:1 low range. It's just tooooooo low for Michigan, so I'm trying to do everything in high range. And every once in a while I go to low range.
Old January 2nd, 2012, 08:56 AM   #7
reptile610
reptile610's Avatar
Send a message via AIM to reptile610 Send a message via MSN to reptile610 Send a message via Yahoo to reptile610
i wonder if a 4 cyl would make a difference on this chart.
reptile610 is offline   Reply With Quote
Old January 10th, 2012, 04:12 PM   #8
Joe87
Joe87's Avatar
Your rpms are the same with any motor what affects rpms is transmission axle ratio and tire size
Joe87 is offline   Reply With Quote
Old February 28th, 2012, 02:31 AM   #9
drew454u
drew454u's Avatar
Also keep in mind it is dependent on what motor you have, I diesel will love lower rpm's and still make power. however a 4cyl will be useless in that rpm range.
drew454u is offline   Reply With Quote
Old March 5th, 2012, 09:11 PM   #10
crazygrady127
Wow Shawn I always asumed you had a d44 in that
Old May 30th, 2012, 09:39 AM   #11
Wramblerguy
Wramblerguy's Avatar
This might help for the jeep guys who want to calibrate their speedo
http://www.quadratec.com/jeep_knowle...article-46.htm
Old October 28th, 2013, 09:22 PM   #12
TCxOUTLAW
TCxOUTLAW's Avatar
i just threw 33s on my xj its pretty sluggish so ill be going to 4.10s this weekend.. i drive almost 2000 miles a week other wise id go with a higher gear
TCxOUTLAW is offline   Reply With Quote
Page generated in 0.46051 seconds with 59 queries
