Welder comparisons. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 27th, 2008, 07:06 PM   #1
BMFmike
meh.
BMFmike's Avatar
Default Welder comparisons.
I was all set on getting a Hobart Handler but after talking to a few experienced welders and a few non experienced (salesmen :tonka:) I am a wee bit torn between the Handler 210 and the Ironman 210.
http://www.northerntool.com/webapp/w...6866_200336866
http://www.northerntool.com/webapp/w..._340600_340600
The welder will be used for suspension and body welding along with aluminum tree stands and what not. Thoughts?
Old March 27th, 2008, 07:08 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
I'd go for the Ironman if you can afford it.
Old March 27th, 2008, 07:35 PM   #3
BMFmike
meh.
BMFmike's Avatar
Reasoning? I would appreciate it
Old March 27th, 2008, 10:03 PM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I don't know anything about Hobart welders... but this may help you.
http://grandrapids.craigslist.org/tls/616177524.html
JcrOffroad
Zoom Zoom!
Old March 27th, 2008, 10:33 PM   #5
BMFmike
meh.
BMFmike's Avatar
What MIG's do you use at JCR?
Old March 28th, 2008, 12:09 AM   #6
jeepguy74
jeepguy74's Avatar
i have the ironman and i love it it welds great and is mega easy to use and being that it is its own cart you wont have that expense as you will need some way to carry around your tank if you plan on welding with anything but flux cored wire.....
i picked mine up at tractor suply for the same price..well i believe it was just under that..
oh and with the larger welder you will be able to use a larger spool of wire thus saveing you the hassel of running to the welding shop as much to get wire...
Old March 28th, 2008, 12:15 AM   #7
bigcountrysg
Countryboy
bigcountrysg's Avatar
I like my millermatic dvi I got it brand new off ebay for a great price.
bigcountrysg is offline   Reply With Quote
Old March 28th, 2008, 12:16 AM   #8
Nuggets
I fix stuff!
Nuggets's Avatar
I like Miller welders. I have a Millematic 130 that does a good job on smaller stuff. I use it on exhaust and other thin stuff. I use .023 wire in that unit so it is smooth and easy to control. I have a Snap On Muscle Mig 250 I use on the big stuff. I use .035 wire in this unit and have found it to be a very capable machine. The Snap On welder is somewhat sensitive to wire speed but once dialed in makes for some really nice welds. This unit also has a Tig and spool gun attachment. The Tig can't be used on aluminum ( I didn't know that when I bought that part) but the spool gun does a great job for aluminum, especially cast.
Old March 28th, 2008, 07:06 PM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
We have 1 Lincoln 215 and 2 255's.
I would recommend the 215 as the best bargin. You can sometimes find them for ~$1400 if your local supply will match online prices.
Benefits over the Ironman would be:
15' welding lead as opposed to 10'
The 215 has an all metal drive assembly (unsure on the Ironman)
At 170 amps the 215 has a 70&#37; duty cycle... The Ironman is 40% at 150amps.
I don't know how much you plan on using it at once, so duty cycle may not be a concern?
Also check cost of consumables for each model.
JcrOffroad
Zoom Zoom!
Old March 28th, 2008, 08:55 PM   #10
Love my Lincoln powermig 210, duty cycle is what sets them apart
Old March 28th, 2008, 09:26 PM   #11
incogrhino
i pull out
incogrhino's Avatar
miller 212 and love it.
incogrhino is offline   Reply With Quote
Old March 29th, 2008, 11:11 AM   #12
BMFmike
meh.
BMFmike's Avatar
At 170 amps the 215 has a 70% duty cycle... The Ironman is 40% at 150amps.
Thanks for the info, I got to talk more to my welding buddy and we agreed on the Ironman and the duty cycle would not be an issue.
I am dealing with the guy on craiglist right now, but I also have a friend that works at TSC for the discount
Old March 29th, 2008, 12:08 PM   #13
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Real good infor here. I use Millermatic 210 at work (but it was stolen a few weeks ago) and a Millermatic 251 at the house. The Lincoln and Miller are about the same with features, can't go wrong with either but with a Hobart I real don't know much about them.
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old March 29th, 2008, 02:58 PM   #14
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Hobarts are low end Miller's.
Old March 31st, 2008, 05:07 PM   #15
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Hobarts work great...
Old March 31st, 2008, 06:07 PM   #16
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
X2
Make sure you have a metal drive assembly.
Old March 31st, 2008, 10:06 PM   #17
brimy311
Smells like a Fork Liftis
brimy311's Avatar
My hat in the ring...
Get the best welder you can afford. Try to stay with Blue or Red machines. Get more welder then you think you need. Buy Used. Use craigshelper.com to search for used machines. If it's Red or Blue you will be able to get parts for it no matter how old the machine is. If you look around, you can find a mig with a bottle for about $1000.
JcrOffroad.com
Like us on Faceook!
Old April 1st, 2008, 12:35 AM   #18
Icebreaker88
Icebreaker88's Avatar
X10000000
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old April 1st, 2008, 09:49 AM   #19
BMFmike
meh.
BMFmike's Avatar
Thanks, I am watching craiglist really close and trying to see if the local welding supply will match online pricing.
Old April 1st, 2008, 09:53 AM   #20
brimy311
brimy311's Avatar
If you don't mind driving:
These guys get all of our business and have always treated us WAY MORE then fair. They will make you a good deal on a machine, in fact I think they have a used Lincoln 255 there. Ask for Todd or Steve and Tell them Jcr sent you.
Praxair
1119 E Walnut St
Kalamazoo, MI 49001
(269) 276-0442
JcrOffroad.com
Like us on Faceook!
Page generated in 0.37368 seconds with 83 queries
