excursion axles vs. super duty axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 27th, 2008, 01:00 PM   #1
barry1me
Just another day
barry1me's Avatar
Default excursion axles vs. super duty axles
I have been looking for some V10 excursion axles with 4.30 gears to swap out my 3.73's for. I was always under the impression that the super duty and excursion axles were the same. Come to find out the F250 axles have calipers on the opposite sides on the rear. The excursion axles have the calipers both on the backside of the vehicle. I also found out that the Dana 50 had a 10mm hub flange on the 99's and the newere trucks had a 13mm flange. There may be other differences, but these are what I have came up with so far. So now finding some 4.30 axles is going to be a bit tougher.
barry1me is offline   Reply With Quote
Old March 27th, 2008, 01:52 PM   #2
masterbeatty
masterbeatty's Avatar
the excursion/250 run a dana 50 where the 350 runs a dana 60. some 250s come with a 60. and there identical if ya just look at them.
Old March 27th, 2008, 08:36 PM   #3
mudbillyredneck
mudbillyredneck's Avatar
I think 50's are ttb (with wimpy little 44 spiders inside the carrier)....where as 60's are solid......but I wouldnt have any clue about something that new.....
so I guess I'm no help....
mudbillyredneck is offline   Reply With Quote
Old March 27th, 2008, 08:44 PM   #4
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
no many of the '99 and up run a solid D50 front axle...not a TTB setup.
Old March 27th, 2008, 08:51 PM   #5
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
I don't know about the rest of the Super Duty Fords but my 2000 4x4 F-250 Powerstroke has the 10.25 and not a dana 60. The rear covers look identical except the 10.25 is smaller.
GNJEEPN is offline   Reply With Quote
Old March 27th, 2008, 08:53 PM   #6
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
talking about a D60 front not rear. All 99 up Super Duty/X's have the Sterling axle.
Oh you should have a 10.5 rear, I believe the 10.25 where the '97 and older F250/350
Old March 27th, 2008, 09:10 PM   #7
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
http://www.foxautoparts.com/
they have a front one with 13mm hubs for 850
Old March 27th, 2008, 09:10 PM   #8
barry1me
Just another day
barry1me's Avatar
Yes you are correct. I knew that the 99-04 had the Dana 50 SA in the front, and the 99+ have the sterling 10.5.
My 05 F250 PStroke had a dana 60 front axle..coil over. What I was curious of is what the differences are between F250 axles and Excursion axles are? I found a set of excursion axles for $1100 for front 4.30's and rear 4.30's with a LSD. Problem is the 99 F250's(what I own) 10.5's rear calipers are clocked opposite of each other, where as the Excur has both calipers faced at the back of the truck....not sure what implications are about installing these. Also the excur has a 13mm flange in the front hub where as the 99 F250 has a 10mm flange....
Old March 27th, 2008, 09:11 PM   #9
barry1me
Just another day
barry1me's Avatar
yeah I spoke with Joey over there today and thats what he told me...they also have a 10mm flanges part too. Im curious to know if the 13mm hub will work on my truck(99 F250)!?
Old March 27th, 2008, 09:11 PM   #10
04 EDGE
04 EDGE's Avatar
http://www.dixautorecyclers.com/
they have a rear one for 650.
both have 4.30 gears
Old March 27th, 2008, 09:13 PM   #11
barry1me
Just another day
barry1me's Avatar
Thanks for the help man....your a good guy
Old March 27th, 2008, 09:16 PM   #12
04 EDGE
04 EDGE's Avatar
www.car-part.com
Old March 27th, 2008, 09:18 PM   #13
barry1me
Just another day
barry1me's Avatar
Do you know if these places will do any type of trade with my axles?
Old March 27th, 2008, 09:27 PM   #14
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
So $1100 for two axles to swap in just to get 4.30 gears. Why don't you just swap in a new set of 4.30:1 gears instead of complete axles?
Old March 27th, 2008, 09:47 PM   #15
mudbillyredneck
I like pizza
Old March 27th, 2008, 09:53 PM   #16
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I like pizza
Hi Steve
Old March 27th, 2008, 11:15 PM   #17
bender
Your daily fullsize fix.
bender's Avatar
Send a message via AIM to bender Send a message via MSN to bender Send a message via Yahoo to bender
SD's switched from the 50 to the 60 around 2003'ish.. wasn't a 250 or 350 thing.
bender is offline   Reply With Quote
Old March 28th, 2008, 07:46 AM   #18
masterbeatty
you will also have to figure out how to mount the coils on the front. since they came with leafs. it shouldnt be hard.
Old March 28th, 2008, 08:28 AM   #19
barry1me
Just another day
barry1me's Avatar
from what I have seen its going to cost a little more then $1100 for gears, and a master install kit + labor. And If I swap out axles I can sell mine and recoup some of the cost.
Old March 28th, 2008, 08:29 AM   #20
barry1me
Just another day
barry1me's Avatar
The 03 and 04 D60 front axles were leaf sprung. 05 is when they went to coil overs.
Page generated in 0.29746 seconds with 83 queries
