1" square or 1" round? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 27th, 2008, 11:15 AM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default 1" square or 1" round?
which is stronger. soon i'm going to be building a new frame for my gokart and would like to know which is stronger. 1" square stock or 1" round pipe? not sure how thick i wanna go yet maybe .125 wall. square is alot easier for me to weld so i'm leaning twards that right now. any input would be helpful as i'm not much of a fabricator
Old March 27th, 2008, 11:16 AM   #2
beejers
always building
beejers's Avatar
round.
beejers is online now   Reply With Quote
Old March 27th, 2008, 11:21 AM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
how much is the diffrence? like significant or will it not really matter much?
Old March 27th, 2008, 11:23 AM   #4
Pokerob
hug life
Pokerob's Avatar
just use square since it sounds like that is what your going to use no matter what anyone says..
Old March 27th, 2008, 11:24 AM   #5
beejers
always building
beejers's Avatar
for a normal gocart i would go with square. something thats going to do huge jumps and go real fast, round.
Old March 27th, 2008, 11:34 AM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
alright. i'll probably build the frame from round tube, but i'm designing my own front suspension setup similar to that of a dune buggy being long travel equal length control arms with a coil over shock setup. i'd like to use square for that because i can mount the bushings in it easier.
Old March 27th, 2008, 11:38 AM   #7
It depends on the direction its being loaded in, but in 'normal' orientation, square is stronger than round, for bending.
0.125 wall is overkill for a go kart.
Old March 27th, 2008, 11:47 AM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what size would you reccomend? like i said idk much about fabrication or steel for that matter. this kart will eventually be powered by a yamaha warrior 350 engine and have full suspension and i will put it through some hell so i want it to withstand the abuse and not crack the frame. my frame is cracked badly in the front and have had to reweld it 2 times already.
Old March 28th, 2008, 07:48 AM   #9
orionn
orionn's Avatar
Use round tube to build it. check to see what materials the tube is made from, you want to be sure its structual tubing, not non-structual like gas pipe/conduit ect.
Use 0.125 for the main chassis, and 0.095 for the non-structual parts.
Use gussets to help with load handling.
If you can, use a bender rather than cutting and welding.
orionn is offline   Reply With Quote
Old March 28th, 2008, 08:03 AM   #10
95geo
newbie
95geo's Avatar
ideally you want unequal length arms, with proper geometry it will keep the contact patch of the tire square to the gound while the chassis leans. look up trophy trucks and class 1 cars for examples.
if you are going to actually go through with making a chassis and you want it to hold up you might as well make it correctly so you are satisfied with the results.
Name:	not quite.jpg
Last edited by 95geo; July 22nd, 2008 at 10:23 AM. Reason: needed to host a picture
Old March 28th, 2008, 08:07 AM   #11
chizzel21
SWAMPBUCKS OFFROAD
chizzel21's Avatar
I Would Use Round Tube Much Better!
chizzel21 is offline   Reply With Quote
Old March 28th, 2008, 09:22 AM   #12
chevotass
chevotass's Avatar
i would use PVC and then fill it with rebar and cement
Old March 28th, 2008, 06:41 PM   #13
1badzuk
1badzuk's Avatar
x2 add duck tape
1badzuk is offline   Reply With Quote
Old May 7th, 2008, 06:29 PM   #14
chainbrain2002
chainbrain2002's Avatar
Send a message via Yahoo to chainbrain2002
Id build the base frame from flat stock, its alot easier to weld to, then the cage and rest of the body in round. stronger torsional rigidity. happy wheeling.
chainbrain2002 is offline   Reply With Quote
Old May 21st, 2008, 05:22 PM   #15
nates4x4
nates4x4's Avatar
I'll probably have a lot of people go against what I say, but I would honestly check into 3/4" pipe which is approximately 1 1/8" O.D. (you can find a chart online, pipe diameters are never exactly what they say they are, inside or out). It will be thicker, cheaper. The downside is that it has a welded seam unlike round tubing and is not rated as structural but rather as a pressure vessel. Although square tubing will also have a weld seam, and some round does unless it is labeled D.O.M. (Drawn Over Mandrel). For a roll cage, no way. For a go-kart on the cheap, I'd say why not. You may find it's a little heavier than what you need but if the extra weight is not an issue I really don't think you'd have problems building a go-kart with it.
nates4x4 is offline   Reply With Quote
Old May 21st, 2008, 05:27 PM   #16
nates4x4
nates4x4's Avatar
P.S. if you do end up going with pipe or seamed tubing, try to keep the seam in the inside of your bends. We use pipe for several non-structural parts and have great success with it, and it saves money. If you want to "do it right" though, go with D.O.M. tubing, it's very high quality steel.
Old May 21st, 2008, 06:46 PM   #17
Even DOM is welded seam.... You might notice there's a good thread about pipe at the top of this forum...
Old May 21st, 2008, 09:06 PM   #18
clint357
Web Wheeler Extraordinair
clint357's Avatar
Yes, that's true. People always get confused because everyone says that the arch is the strongest shape, but that's for a totally different function. Look at what shape buildings are and what they are made of.
clint357 is offline   Reply With Quote
Old May 22nd, 2008, 02:25 PM   #19
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Huh? D.O.M. is Drawn over a mandrel hence the DOM and why it's seamless. Sure your not thinking of HREW tube?
Old May 22nd, 2008, 05:35 PM   #20
No, its seam has been flattened, but it still starts life as welded seam.
So, 'HREW' and DOM, such as ASTM A513, tube start as flat bar, which is rolled and welded.
Seamless tube, like ASTM A519 starts as round bar, and is pierced to make truly seamless tube. Very common for gas line applications.
People like to call DOM seamless, becase it doesn't have a big bump at the seam, but the seam is there. Its just been worked.
Tags
acid, gocart of death, haggar is douche
Page generated in 0.57028 seconds with 84 queries
