from spool to detroit in a 9 inch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 26th, 2008, 09:16 PM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default from spool to detroit in a 9 inch
will i need anything that i would need other than the locker itself if im moving from a spool to a detroitin my 9 inch rear axle. my detroit looks like this
i dont know if i need anything else before i install it. any info is good in my book.
nate4d is offline   Reply With Quote
Old March 26th, 2008, 09:21 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
im assuming you have a mini spool in there now and not a full carrier spool.. if thats the case then the locker is all you need.
Old March 26th, 2008, 10:24 PM   #3
nate4d
Gnarley Davidson
nate4d's Avatar
im unsure to be honest cuz i havent gotten the axles yet and the owner doesnt know whats in the rear. if its a mini or full spool.
Old March 26th, 2008, 10:25 PM   #4
nate4d
Gnarley Davidson
nate4d's Avatar
whats the worst case if i have a full?
Old March 26th, 2008, 10:27 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
need a new carrier and setup/install of gears
Old March 26th, 2008, 10:31 PM   #6
kickstand
circling the drain
kickstand's Avatar
just leave it spool, its the way to be
Old March 26th, 2008, 10:32 PM   #7
nate4d
Gnarley Davidson
nate4d's Avatar
haha not as a dd. or else i would
Old March 26th, 2008, 10:32 PM   #8
nate4d
Gnarley Davidson
nate4d's Avatar
new carrier and install kit u mean? gimme a list john! dammit. haha
Old March 26th, 2008, 10:39 PM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Thats not a Ford 9" detroit, at least mine didn't look like that. that one looks like a14bolt Detoit.
up right hand corner of this pic is what a 9" detroit looks like
The detoit replaces the whole carrier, so it doesn't matter if you have a spool or mini spool right now. Just get a rebuilt kit, so you can freshen up the bearings/seals. If you are changing ring and pinions you should have a install kit anyway.
I
Old March 26th, 2008, 11:43 PM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Besides tire wear (and only if you drive the Detroit right) a spool is better in almost all regards in a DD IMHO.
JcrOffroad
Zoom Zoom!
Old March 26th, 2008, 11:52 PM   #11
Nuggets
I fix stuff!
Nuggets's Avatar
Did that for years too. FYI, a Detroit locker is going to make lots of noise during turns and you may find that you get some tire chirping.
Old March 26th, 2008, 11:59 PM   #12
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
especially if you have a stick from what I read.
Old March 27th, 2008, 12:38 AM   #13
nate4d
Gnarley Davidson
nate4d's Avatar
i do have a stick.
Old March 27th, 2008, 12:48 AM   #14
nate4d
Gnarley Davidson
nate4d's Avatar
so this isnt a detroit for a 9inch?
Old March 27th, 2008, 12:52 AM   #15
ddeadserious
ddeadserious's Avatar
I'd say just leave the spool as it's already installed. I've heard alot of Detroits don't do much unlocking on light Jeeps, so it may end up acting like a spool anyways.
ddeadserious is offline   Reply With Quote
Old March 27th, 2008, 01:05 AM   #16
nate4d
Gnarley Davidson
nate4d's Avatar
http://www.power-trax.de/produkte/locker/locker-e.htm
look at the 4th picture down on the left side under 100&#37; locker. it looks like maybe it goes inside the carrier..
any thoughts?
Old March 27th, 2008, 01:17 AM   #17
nate4d
Gnarley Davidson
nate4d's Avatar
I Need Help!
Old March 27th, 2008, 01:28 AM   #18
ddeadserious
look at the 4th picture down on the left side under 100% locker. it looks like maybe it goes inside the carrier..
any thoughts?
I'd say it looks like it goes into the carrier, considering there's nothing for the ring gear to bolt to. But what the hell do I know.
Old March 27th, 2008, 02:11 AM   #19
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
No.
http://search.ebay.com/detroit-locke...0lockerQ209Q22
JcrOffroad
Zoom Zoom!
Old March 27th, 2008, 02:28 AM   #20
Pre4runner
Bike Dude
Pre4runner's Avatar
Run the spool on the road, i've been running my XJ welded for a year and other then sqealing a bit when parking its just fine. Tire wear isn't uneven or anything. I've also run my toyota welded with no problems other then tickets.... And i have run a locker in the rear and it would only unlock when turning into a tight spot clutch in. Other then that it was almost always locked up.
And the locker you have does look like its for a 14 bolt.... just welded one of those too.
Page generated in 0.40526 seconds with 83 queries
