what would you do - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2008, 09:17 PM   #1
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
Default what would you do
so i have a dana 30 out of a 94 wrangler, i have a one piece shaft from a newer TJ but the housing wont accept the inner seal so i was thinking of just welding the two shafts together.
is this a good idea?
and BTW this axle is going to go in a 97 ranger SAS.
we are on a budget
Old March 25th, 2008, 09:22 PM   #2
ddeadserious
ddeadserious's Avatar
man there is so much on the internet regarding this swap.
PM Jeeperz Creeperz for the seal numbers, it just needs different seals, not expensive ones or anything. I don't feel like searching for the part numbers right now.
And I think welding the shafts together is an absolutely awful idea.
ddeadserious is offline   Reply With Quote
Old March 25th, 2008, 09:27 PM   #3
Daniel
SFA Ranger
Daniel's Avatar
i have the part numbers still from the thread i posted.
i vote we use the one piece shaft seeing as we already have it.
Daniel is offline   Reply With Quote
Old March 25th, 2008, 09:30 PM   #4
Daniel
SFA Ranger
Daniel's Avatar
OR...
we could get a manual cable actuator for it.
Old March 25th, 2008, 09:40 PM   #5
Daniel
SFA Ranger
Daniel's Avatar
this is all i can find on the cable thing.
http://www.bc4x4.com/tech/2002/d30sh...or/diagram.gif
does anyone make a manual cable setup?
Old March 25th, 2008, 09:47 PM   #6
ddeadserious
It's called posi-lok.
It's really not worth the effort to get it working correctly, especially considering you already have the 1-piece shaft. It's a downgrade. The TJ shaft has a bigger/stronger u-joint than the disconnect 2-piece shaft. Being able to disconnect the axle shaft just doesn't really matter.
Old March 25th, 2008, 09:49 PM   #7
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
all i did when i snapped my 2 peice shaft into a 4 peice shaft lol, was a grab a one peice and tossed it in.. it never leaked fluid or anything...
Bronco Sally is offline   Reply With Quote
Old March 26th, 2008, 12:22 AM   #8
Daniel
SFA Ranger
Daniel's Avatar
holy crap those are expensive!
orly, are you sure it isn't leaking?
i don't understand what would seal it. :miff:
Old March 26th, 2008, 01:09 AM   #9
PavementPounder
PavementPounder's Avatar
Just do the searches, make the phone call to Jeeperz Creeperz, and swap in the 1-pc shaft correctly.
Old March 26th, 2008, 05:22 PM   #10
04 EDGE
04 EDGE's Avatar
well pulled the diff out of the other axle and it had a seal installed at the carrier so all is good!
Old March 26th, 2008, 05:30 PM   #11
Daniel
SFA Ranger
Daniel's Avatar
Page generated in 0.28534 seconds with 56 queries
