Wd-40? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2006, 07:37 PM   #1
MoparMike
MoparMike's Avatar
Default Wd-40?
Why do so many people use WD-40 as a lube? Im not being a smart *ss, from what I understand WD-40 is an abrasive, but why do so many people spray it on things like chains to lube them?
MoparMike is offline   Reply With Quote
Old April 1st, 2006, 07:44 PM   #2
going-strong
'96 360 sport 4x4
going-strong's Avatar
it says right on the can that it:
-lubricates
-cleans
-protects
-penetrates
-displaces moisture
going-strong is offline   Reply With Quote
Old April 1st, 2006, 08:38 PM   #3
MoparMike
MoparMike's Avatar
how can it lubricate if it displaces moisture?
Old April 1st, 2006, 08:47 PM   #4
Kawierider
Kawierider's Avatar
oil lubricates better than water. You dont want moisture in anything, wires, or bolt holes, or anything mechanical becuase it will rust.
Old April 1st, 2006, 08:54 PM   #5
deuce228
Redneck Poser
deuce228's Avatar
I never use WD40. Always have a can of deep creep or pb blaster on hand, and use white lithuim to lubricate most things.
Old April 1st, 2006, 09:02 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
another good product to try is stuff called seaform deep creep. I know its a great product but i was just told you can use it for fogging oil in cylinders to store engines.
Old April 1st, 2006, 10:45 PM   #7
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
It's also bitchin for removing sticker residue.
I've never heard of it being an abrasive, I don't think it would be too good on clear plastics though, and I heard it's best to avoid painted surfaces with it as well (like for de-icing door locks in the winter).
Old April 2nd, 2006, 12:12 AM   #8
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I spray tube with it before I bend it... that is mostly all I use it for.
PB blaster for stuck stuff.
JcrOffroad
Zoom Zoom!
Old April 2nd, 2006, 03:11 PM   #9
going-strong
'96 360 sport 4x4
i use white lithuim to lubricate, and pb blaster for things that are stuck, but i always have a can of WD40 to use incase my spark plug wires get wet or something like that
Old April 2nd, 2006, 03:27 PM   #10
vwBOY
it's how i roll
vwBOY's Avatar
wd-40 is 70% keroseine
vwBOY is offline   Reply With Quote
Old April 2nd, 2006, 03:48 PM   #11
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
No. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents. Straight from the web site.
Old April 2nd, 2006, 04:01 PM   #12
deuce228
Redneck Poser
deuce228's Avatar
That was the product I was talking about.
Old April 2nd, 2006, 05:17 PM   #13
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Look at the source of who said it contained kerosene. :miff:
Old April 2nd, 2006, 06:34 PM   #14
clarkstoncracker
lol
clarkstoncracker's Avatar
Are you retarded?
Old April 2nd, 2006, 06:40 PM   #15
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Gm use something simular called MP50 and its a mosture displacement lube. GM also has Heat Valve Lubricant. its ammonia based and will eat the rust out a the Titanic. its good stuff if you ever want to try it just go to the dealer and get some.
Yetti
Old April 2nd, 2006, 06:42 PM   #16
Yetti
Yetti's Avatar
oh, all most forgot. theres this stuff called "iron Clad" its a lithium based spray for preping engine blocks & cranks for storage. kind looks like snot but it won't wash off sitting in the garage.
Yetti
Old April 5th, 2006, 10:09 AM   #17
84Scrambler
WD is short for water displacement. The number 40 represents that this was the 40th formula that they tried before they got one that worked. Thus WD-40. It is advertised as a lubricant basically as a marketing ploy. How many people are in the market for a water displacement spray vs. looking for a lube or rust penetrant. It will do these other things, but is far from what it was designed to do. PB Blaster or Seafoam Deep Creep are much better as rust penetrants.
Old April 6th, 2006, 07:37 PM   #18
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Tri-Flow http://www.triflowlubricants.com/
Old April 6th, 2006, 09:47 PM   #19
user name
keep your stick onthe ice
user name's Avatar
well stated and true
Old April 6th, 2006, 10:14 PM   #20
Pre4runner
Bike Dude
Pre4runner's Avatar
Yea im a bike tech and everyone thinks wd-40 is chain lube or good for it... Its terrible it eats away grease and definatly does not lube stuff at all... Everything has its own special style of grease or lube... hell if it didn't oil would fill the tranny engine and diffs. Then there are things that are good for lots like lithium grease... try flow is a good light lube too. and im a fan of pb for those stubburn bolts
Page generated in 0.39554 seconds with 83 queries
