How much do you think my Camaro is worth? (pics) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2008, 01:53 AM   #1
Twisted Pleasure
Wanna-b-big
Twisted Pleasure's Avatar
Question How much do you think my Camaro is worth? (pics)
as bad as i dont want to im kind of kicking around the idea of selling my camaro, its a 1978 z28 that ive had since i was 16, its been a project for me ever since. last summer i tore out the old motor and put a new one in. i dont even know how much stuff i put into it but ill try to remember.
brand new 355 Blueprint crate engine, im talkin brand new, started twice since i put it in. so its still not broken in. dynos at almost 400 horse, $3,445.00, warranty for 30 months or 50,000miles, started last july i think.
flowtech headers
3in dual exhaust
flowmaster mufflers
traction bars
holley 650 double pumper
big k&n air filter
nice holley fuel pump
accel distributor
a super hot coil
fat tires on the back, killer look
interior-needs the driver seat redone, and the door panel redone, other than that its not bad at all
exterior, is a little rough, if you want it really nice it needs to be repainted, and either some bondo or new panels which are cheap for z28's, radiator was just flushed cleaned and painted. new water pump, hi flow fan, B&M stall converter i believe its a 2500 stall, not sure on the gearing in the rear, the tranny acts sticky sometime, but not always. custom sunroof that doesnt leak. power windows that work...sometimes. msd ignition wires, i have an extra intake for it and a bunch of other stuff i know im leaving stuff out but just getting an idea. these pics are from last year and the car looks good in em. its not in mint condition, but far from a junker. just let me know what you guys think, thanks.
Twisted Pleasure is offline   Reply With Quote
Old March 25th, 2008, 01:59 AM   #2
Weasal
Better than Newbie
Weasal's Avatar
bout trey fitty
is that a hair net on the engine?
dude, buy a car cover.
Weasal is offline   Reply With Quote
Old March 25th, 2008, 02:37 AM   #3
Twisted Pleasure
Wanna-b-big
Default The Motor
Base 355 Vortec
BP3550CT
$3,445.00
Block:
4 bolt main block
Passenger side dipstick
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
New SCAT cast crankshaft
Keith Black Hypereutetic pistons
Chevy heavy beam rods with 150,000 psi bolts
Hastings Moly rings
Balanced rotating assembly
Melling high volume oil pump
Flat tappet hydraulic lifter camshaft
Heavy duty double roller timing set
Cylinder Heads:
New Cast iron "vortec" heads
1.25 diameter valve springs
Hardened retainers and springs
2.02 swirl polished intake valves
1.60 swirl polished exhaust valves
Hardened push rods
NOTE: THIS ENGINE WILL NOT WORK FOR APPLICATIONS REQUIRING EGR
A Ton Of Extras:
Professional Products dual plane satin finish intake manifold
9.5 to 1 compression
New chrome valve covers
Brass freeze plugs
Dyno tested and shipped with results
Comes with 30 month / 50,000 mile warranty
Critical Specs:
Camshaft:
.480 Int / .486 Exh & 224 Int / 230 Exh duration @ .050 - 110 degree lobe sep.
Horsepower:
385
Torque:
405
Compression Ratio:
9.5 to 1
Ignition Timing:
13 to 16 Degree Initial / 34 Degree Total
Old March 25th, 2008, 06:54 AM   #4
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
$3000ish
Old March 25th, 2008, 06:56 AM   #5
TopThrillJoe
TopThrillJoe's Avatar
Send a message via AIM to TopThrillJoe
$3100
TopThrillJoe is offline   Reply With Quote
Old March 25th, 2008, 07:29 AM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
to the right person that cars worth 6000 with currently installed parts. matter of fact i know someone who likes 2nd gens so i'll run all that by him.
Old March 25th, 2008, 07:40 AM   #7
JEEPR
Playing Possum
JEEPR's Avatar
I had a 79. Factory 4spd car..
Unfortunately it's not worth much more than what the motor cost you. Keep it and drive it. You will just be sorry later on if you give it away now. You will hit your mid-life crisis and spend a ton of money to buy someone else's Camaro that is "just like the one I had in High School."
JEEPR is offline   Reply With Quote
Old March 25th, 2008, 07:47 AM   #8
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
thats what i was thinkin when i seen the pics....life goes by too fast
hawkscj5 is offline   Reply With Quote
Old March 25th, 2008, 08:11 AM   #9
Strangler
Strangler's Avatar
2-3k. Keep it or keep the engine and sell it as a roller.
Old March 25th, 2008, 08:17 AM   #10
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
i would say list for 6000 and see what happens. if ya cant get over 5000 i would pull motor and try and sell roller for about 3-3500
Silver Bullet is offline   Reply With Quote
Old March 25th, 2008, 08:30 AM   #11
Disturban
Disturban's Avatar
And the right length plug wires!
Old March 25th, 2008, 08:39 AM   #12
KartRacer
Blowd up
KartRacer's Avatar
New wheels that don't stick out a half mile.
Old March 25th, 2008, 09:06 AM   #13
Bishop
Bishop's Avatar
its not worth it to sell it. my dad has a 77 with only 22,000 miles and in mint condition, all stock. and its not worth a thing. their more fun to drive then the money you would get out of it
Old March 25th, 2008, 09:38 AM   #14
x2 thats why i still own my 77 trans am and have only put 4K in mileage on it in 4 years....
i say 3000-3500
if ya shorten the wires, add an heater box, and a fan shroud,and a real air cleaner (just pray your engine never has a sputter through the carb cause it'll catch the foam on fire and melt down into the carb) maybe 3750.....FWIW
Old March 25th, 2008, 10:15 AM   #15
rockrat
rockrat's Avatar
edelbrock carb cover/breather, had one on my roadrunner when I bought it. Actually starves the engine a little; 1" thick foam. Get rid of it, if the engine backfires once through that carb, you better have an extinguisher on hand.
Keep the car, I sold my muscle car, and have been kicking myself in the balls ever since.
rockrat is offline   Reply With Quote
Old March 25th, 2008, 10:19 AM   #16
Rob the plumber
Those 2nd gens are starting to fetch more coin, but that is for ones that are done nicely, or stock and clean. Unfortunately this one has a lot signs of the mullet-mobile.
Old March 25th, 2008, 10:23 AM   #17
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
if it were to me i'd say 1k, but thats because i hate these cars. Ugly as sin, but like said above, get the rite person looking for one and you could get some money from them.
Why are you selling? Pull the engine and throw it in somthing else
Old March 25th, 2008, 11:53 AM   #18
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
x2.....I would keep it and make it into "what you want". Trust my coming from a Camaro guy! I'll be buried in mine..........:tonka: I think you could get $4,500 to be honest.
Red68Camaro is offline   Reply With Quote
Old March 25th, 2008, 12:05 PM   #19
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
lift it....
no seriously DON'T!
Old March 25th, 2008, 12:15 PM   #20
Bones
Bones's Avatar
at least that is a performance mod... the only way to get fast radials without tubbing the body/chassis.
I bet this thing would actualyl rip pretty well on a track
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.40719 seconds with 82 queries
