Stubborn Allen head @#$%&* Bolt.. tips for removal ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2006, 04:12 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default Stubborn Allen head @#$%&* Bolt.. tips for removal ?
It connec ts the block to the transmision.. i know i shouldnt be an alen head bolt but it is.. if i ever see the person who put that in thre i'll stab them in the eye with a hot soldering iron !
Bbut anyway.. the only way ive been able o get on it is with an extension because its between two cooler lines for the trany and of course its a 69 motor so everything has a nice thick coatin of grease/oil so torch is out of the question... any good way to get on this thing STRONG so i can break it loose or snap te head off( at least then i can get the motor out) ??
ME> <Allen bolts
Old April 1st, 2006, 05:48 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you have to cut off an allen wrench so you can put it in a socket to reach past the cooler lines. use a die grinder it goes right through them. if by chance its so worn it needs more bite use a torx bit and pound it in so it real tight. then it won't slip out.
Yetti
Old April 1st, 2006, 08:06 PM   #3
x2
Also, for stubborn bolts, soak them continuously for as long as you can.
Normally, I'd say to soak it, but thats probably an issue with a steel bolt and an aluminum housing, so its not a rust issue. They just like to stick.
Old April 1st, 2006, 11:49 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
Originally Posted by Haggar
x2
yes it has a well oiled system of rust prevention.. im sure its just Stuck.. I worked on i a bit more and realized its not Rounded out yet... the hex just won stay in.. :miff: i get a good grip on it and give er shit and it pops out
So i need to get creative with the prybars and fin a way to keep the socket pressed on and give er hell
Old April 2nd, 2006, 01:21 AM   #5
PavementPounder
PavementPounder's Avatar
Same trick as with Torx. Put the socket on with the extension and beat the fukc out of it with a small sledge to drive shocks through the bolt. Then crank on it.
Always works for me on CJ door hinges.
Old April 6th, 2006, 09:52 PM   #6
user name
keep your stick onthe ice
user name's Avatar
i have welded nuts on stipped allen heads with great luck. fill the center with weld and the pounding the torqs in is a good plan to
Old April 6th, 2006, 10:06 PM   #7
Pre4runner
Bike Dude
Pre4runner's Avatar
Well if you have the right allen bit you should have no problem at all... My toyoa uses one allen bolt to hold the intake on... i stripped it getting it out... pounding the next closet allen into it... this case switched from a metric to a standard... Allens are really hard to to strip if you use the right size.
Page generated in 0.21807 seconds with 44 queries
