Corner guard questions/thoughts - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2008, 01:52 PM   #21
TopHeavy
Yikes!
TopHeavy's Avatar
Faster than it takes to blow a rear driveshaft.
I did order a new yoke along with a new Amsteel winch line and new Iroks today, however.
Back on topic: I would be interested in corner guards. I believe we are talking about the PSC Crusher Corner type, correct?
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old March 25th, 2008, 02:22 PM   #22
CreativeFab
used to be Ironman
CreativeFab's Avatar
And you didnt call me for this stuff
and yes the corners would be like the PSC type
Old March 25th, 2008, 04:40 PM   #23
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
I made mine out of 10 gauge (.134). I figured I only really wanted it to protect the body from ripping like an aluminum can when I rubbed it on the rocks. Even 1/4" would bend or buckle when hit just right. I gave it some thought last year about producing some of these because I have the equipment, but wasn't sure if the econmy would support it. For mounting I just punched some square holes for 1/4-20 carriage bolts. Can't give you real world info on if they would hold up (haven't wheeled it in rock since its been done) but I feel they will hold up fine.
TJontherox is offline   Reply With Quote
Old March 25th, 2008, 04:47 PM   #24
Icebreaker88
Icebreaker88's Avatar
Sure would be nice if someone made some corner guards for a Early Bronco
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old March 25th, 2008, 05:33 PM   #25
Tab
Tab's Avatar
Drop it off and I'm sure I can get something made that doesnt look butch. No offense to guys named Butch. I have yet to be unable to get something made after a custom request by a customer.
Old March 25th, 2008, 07:09 PM   #26
1crazyredneck
MichiganRednecks
1crazyredneck's Avatar
Last Pic I seen of that Bronco Mike it needed more than corner guards
1crazyredneck is offline   Reply With Quote
Old March 25th, 2008, 07:33 PM   #27
nosilla
We just made deaner a set a week or so ago. We did his with 3/16th and made them custom. We opened up the wheel well and such. We also gave him Steel flairs to boot.
We don't have them on our site yet but we do make them. Jeepfreak, bring that 2A over and we can get that one done also.
nosilla is offline   Reply With Quote
Old March 25th, 2008, 08:13 PM   #28
Tab
Tab's Avatar
You guys just heated them up and bent them around a form right?
Old March 25th, 2008, 08:35 PM   #29
Deaner
lost
Deaner's Avatar
Send a message via AIM to Deaner
Here is what JP fab has done for mine. they made one-off crushers ( there first time ) and have so far made them look comparable to anyone else. They took almost 1" out of the front, 2"s out of the top, and 4"s out of the rear.
Pricing is comparable to everyone else, but a heck of alot closer than anyone else.
id rather give a local Michigander the money then some one in Cali or who has there shit made for them. These pictures are not the finished product in which I myself have not seen YET!
JP Fabrication has done well so far by me, first time builds take alittle extra thought and care and so far they have accomplished what they needed to! I give JP fab a thumbs up, good luck and I hope this helps you out!!! Oh plus they are easy to work with and do what you ask from them.
what do you guys think?
Cheers
Dean
Originally Posted by Toolmakerprevo View Post
Well at least I can screw comfortably in a bathtub!
Originally Posted by Nuggets View Post
Half you guys bitchin' about these women are probably dragging home snow cows and tundra pigs from the bar.
Deaner is offline   Reply With Quote
Old March 25th, 2008, 09:07 PM   #30
lgottler
lgottler's Avatar
I had a customer of ours try to make some aluminum corner "bling" panels for his TJ. Did it on his own time at our shop, I still have the die we made to bend them with, don't know how close it is to the correct radius, I could check. We went dumpster diving and found a hydraulic cylinder that was damn close and welded crap to it to use on the press brake. The idiot test fitted them on my TJ, scratched up my paint! But I couldn't say much cuz he's a customer...
Personally, I'm leaning towards more of the crush it out of the way group than the keep it together group. If I do anything, it will be something like 1/16" just to cover up the fender a bit after sliding the axle back further. But that I can bend by hand...
I think if you designed it to "not grab" stuff by possibly angling in the lower lips or adding tubing around the lower edge, it might add more strenth (by adding another plane to bend against). But who am I? I would rather have rubber fenders! :) I suck at design!
Lucas
lgottler is offline   Reply With Quote
Old March 26th, 2008, 09:25 AM   #31
PMAC
PMAC's Avatar
I think the radius is very close to 3.5"
PMAC is offline   Reply With Quote
Old March 31st, 2008, 08:02 PM   #32
Gunsworth
Gunsworth's Avatar
SO far the only test my 3/16 corners have gotten was backin off the trailer into my GFs LHS. She needs a new trunk and taillight, I just lost some powdercoat
Gunsworth is online now   Reply With Quote
Old May 19th, 2008, 02:27 AM   #33
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
tab I want a blank set of 1/8 inch yj full corners with no holes or fenderwells how much you charge me? basically just for the steel and the labor to bend it. or if i give you a posterboard template of what i want how much then?
PM if you want, very interested though
Trailrig is offline   Reply With Quote
Old May 19th, 2008, 11:17 AM   #34
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
I don't care about the weight so for me a consumer the price would have to be considerably less to justify less strength.
Page generated in 0.42088 seconds with 65 queries
