Project PROCRASTINATOR - CJ7/YJ/Blazer/Lots Of Tubing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2008, 09:22 AM   #1
1crazyredneck
MichiganRednecks
1crazyredneck's Avatar
Default Project PROCRASTINATOR - CJ7/YJ/Blazer/Lots Of Tubing
Ok Here it goes.. This has been a long drawn out process.. So much with everything else going on that my wife has now calles it the procrastinator.
Anyway here is the End Of the Begining.. Basically after tearing EVERYTHING apart and cutting TONS of brackets off.. I now think I should have for sure just sold it and built a new rig.. But anyway here it goes
This Build started life as a contraption to say the least. It was a Cj5 body lengthend to Cj7 Length with a lot of steel and fiberglass and bondo. It sat 9 inches above a Blazer Frame which had been shortened. It had Pro 9" Coil Overs, A Hillbilly Ford Hybrid Chevy Dana 44 up front ( Did you get all that ) and a 14blt rear with a decent 4 link. I scraped the body, cut all the existing brackets off the frame.. I'm going to clean up all the holes and smooth the frame out. It's getting a Tube Rear Frame Section and a Boxed Front Frame section. It'll have a CJ-7 front and I got a pretty good YJ tub for the Rear. I'm going FOA Coilovers in the 18" Variety and the body is going to be morphed all the way flat with the frame. I know I'm gonna get shit for not going the route of a jeep frame but there was a couple reasons I didn't which I have sorta already regreted.. They where.. I've had several jeeps and honestly .. the one thing I did like about this JeeBlazer was I could wash the thing.. The inside of the frame of my old jeeps just use to fill up with mud and crap.. With this there is non off that.. And the other is.. Hell I'm only using 6-8ft of it.
Anyhow.. Here is the start ..
This Is How I Got The Jeep.
Front Flex Before
Rear Flex Before
Just Starting To Tear It Apart
Frame With Body Off
Removing The Body
Frame Cut Front And Rear ( It Will Be Tube )
Rear Axle With Most Of The Rear Mounts Gone
Big Azz Heim Joint
Rear Disc Brake Brackets
Start Of The Rear Lower 4-Link Brackets
Way To Much Grinding
Lower 4-Link Bracket Tacked On
ADDED 3-24
More Grinding
Testing The New Lower Links - This is Not At Ride Height - And Pinion Angle Isn't Correct
How To Drill Tubing Without A Lathe
How To Tap The Tubing Without A Lathe
Just Checking The Flex A Little
Another Flex
This Is Actually Planned Full Jounce
More To Come.. Can't Wait Till 2morrow.. Get My Steering
1crazyredneck is offline   Reply With Quote
Old March 24th, 2008, 11:31 AM   #2
mudbillyredneck
mudbillyredneck's Avatar
nice build......looks good....any pics of the new-ish body ?
maybe a certain dvd cover will show up in one of these pics ????
mudbillyredneck is offline   Reply With Quote
Old March 24th, 2008, 11:32 AM   #3
Icebreaker88
Icebreaker88's Avatar
Looking good Rich
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old March 24th, 2008, 11:52 AM   #4
1crazyredneck
MichiganRednecks
I'll take some pics of the body.. Thanks Mike.. Your the one that talked me into going with a Full Spool in the front.. I hope I dont regret it..
My Steering will be here Tuesday from PSC.. It's a full hydraulic.. I can't wait to get that on the front.. I'm going to make my own high steer arms since we have a mill.. Hopefully all works out and it'll be done late this summer.. Still haven't decided on a color.. We have a Viper ACR at work that is Black with Charcoal Grey stripes and it just looks sweet.. I'm kinda thinking that..
Old March 24th, 2008, 11:59 AM   #5
beejers
always building
beejers's Avatar
what size bolt goes through those 1 1/4 heim's?
beejers is offline   Reply With Quote
Old March 24th, 2008, 12:04 PM   #6
1crazyredneck
MichiganRednecks
It's a 1" -- I got them from RadialBearing
I chatted with Robin From WhiteKnight.ca and he's run them for 3 or 4 yrs now with no problems.. They are steel on steel with a zerk fitting so you can keep them clean with fresh grease after everyrun..
Old March 24th, 2008, 12:27 PM   #7
95geo
newbie
95geo's Avatar
looks like a good start!
Old March 24th, 2008, 04:00 PM   #8
bigblue2230
still goin
bigblue2230's Avatar
Lookin good. Hope it comes together as good as planned.
bigblue2230 is offline   Reply With Quote
Old March 24th, 2008, 06:12 PM   #9
1crazyredneck
MichiganRednecks
Added A Couple More Pics to the first post.. Rear 4-Link Is now Tacked good into place. Now It's time to start on the front..
Old March 24th, 2008, 08:46 PM   #10
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
What size heim joints are them? the ones that i have are 1" also i like the way u made ur brackets for ur heim joints
CHEVYRCKS is offline   Reply With Quote
Old March 24th, 2008, 08:52 PM   #11
1crazyredneck
MichiganRednecks
I'll give you some of the details on the suspension..
Lower Links Are 1 3/4 dom .375 wall
Lower Link Heims are (Thread = 1.25-12) (Hole Size = 1" thru hole)
Upper Links Are 1 1/2 dom .500 wall
Upper Heims are Chromoly (Thread 3/4-16) (Hole Size 5/8 thru hole)
Most of the Brackets are made from 3/16 3"x4" box cut and shaped
Old March 24th, 2008, 08:55 PM   #12
454 jeep
454 jeep's Avatar
Sweet...
454 jeep is offline   Reply With Quote
Old March 25th, 2008, 05:25 PM   #13
1crazyredneck
MichiganRednecks
Got Some Parts Today From Da UPS man..
Old March 27th, 2008, 03:29 PM   #14
1crazyredneck
MichiganRednecks
Just a Pic Of The Body I'm gonna use.. Needs a little TLC but it'll work out just fine..
Old March 27th, 2008, 03:47 PM   #15
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
just curious where you bought it from, looks very familiar, perhaps you got it out of state?
Old March 27th, 2008, 04:30 PM   #16
1crazyredneck
MichiganRednecks
Got which part.. The old jeep or the body going on it??
Page generated in 0.45386 seconds with 71 queries
