The most labor intensive do-it-yourself beadlocks EVAR - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2008, 08:07 PM   #1
Bones
Bones's Avatar
Default The most labor intensive do-it-yourself beadlocks EVAR
I sold my boggers on H1s and wanted a good option to run a 17" steel rim, beadlocked, with deep backspacing (I didn't want a wider track). I ended up settling on stock Dodge Ram rims. 17x8 with about 5.5" BS... and www.offroadoverstock.com DIY beadlocks (FREE SHIPPING!!!)
The problem is with the deep backspacing. The outer lip of the wheel is so close to the inner dish on the wheel, that if you weld on the inner beadlock ring, there isn't any room to get a nut behind the ring for the beadlocks.
To solve this, I had a buddy (who will never die) burn me a few "spacer rings" to space the inner beadlock ring from the wheel dish. This caused twice the amount of welding... and twice the chances of the beads leaking once they are mounted up.
The pics show the timeline
These are the stock 17" "chrome clad" rims. the chrome is just glued on... but very well done I might ad.
start peeling up the cladding, starting in the center
once you have worked the center of the cladding loose, start on the outside. You might have to cut a line in the outside of the cladding to create a weak spot, so you can fold the cladding over onto itself
and BAM, you have a stel wheel
Now you can see the shallow dish problem I mentioned before... there isn;t enough room for the inner beadlock and a 3/8" nut.
So here are the 3/8" spacers. They were made in quarters to reduce the amount of scrap metal
all burnt in, and ready to weld the inner ring over the spacers
the inner ring burnt in
And the final product.... not sure why the picture turned out grainy... probably because I've dropped my camera one too many times.
They were a ton of work, and are ungodly heavy.... but I like them. They were the cheap way to have rims that don't have a huge offset with outer beadlocks. The 18.5" boggers on H1s put my outside to outside dim at about 84". The 14" Krawlers on 9" beadlocks (the kit adds about an inch) put my outside to outside dim at about 79"
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 23rd, 2008, 11:07 PM   #2
scottie
Eye candy
scottie's Avatar
great only 3 more to do?
Old March 23rd, 2008, 11:12 PM   #3
Tab
Tab's Avatar
Turned out nice. Sometimes you have to do shit yourself just because you can. Who cares if it took 100x longer than buying a set. I know, I've been there plenty of times. I'm recentering my hummer wheels now actually. I even considered buying stamped centers even though I own a cnc plasma table. But now that they are cut and ready to weld in I'm glad I did them. The only problem I see with your wheels is that you didnt buy the rings from me :flipoff:
Old March 30th, 2008, 07:54 AM   #4
silverxj
Recovering XJ owner
silverxj's Avatar
Those turned out pretty sweet, but I have to ask ... why didn't you just recenter your H1's?
Old March 31st, 2008, 07:32 PM   #5
Bones
Bones's Avatar
comp tread tires are only in 17"... I wanted the 42" IROKs stickies or the Krawler stickies.
the H1s are awesome, I wish BFG thought that too
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 31st, 2008, 08:15 PM   #6
BMFmike
meh.
BMFmike's Avatar
What is the width of the axles you are running?
Old March 31st, 2008, 10:38 PM   #7
Bones
Bones's Avatar
stock ford, no idea exactly what it is
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old April 3rd, 2008, 11:37 PM   #8
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
looks good!
71jeepster is offline   Reply With Quote
Old April 5th, 2008, 09:07 PM   #9
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
with the end result i must say it looks worth it
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Page generated in 0.23465 seconds with 50 queries
