302 tuning problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2008, 02:11 PM   #1
88mudder
In the band!
Default 302 tuning problems
After getting my 302 in my Ranger, it doesnt wanna run that well. Its a carbed engine with Edelbrock 4 bbl carb. It will start up and run good up to 2500 rpm. Anything above that it backfires and smokes. It seems to rev kinda slow too. The idle seems decent, it says steady. I was just outside messing with it and I reved it up and then it blew the oil cap off the valve cover.
I need some tips
Old March 22nd, 2008, 02:24 PM   #2
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
what is your timing set at?
Bronco Ollie is offline   Reply With Quote
Old March 22nd, 2008, 02:44 PM   #3
88mudder
In the band!
I havent been able to see a timing pointer on that engine..everybody is telling me its an oddball timing cover. Would you know?
Old March 22nd, 2008, 03:03 PM   #4
88mudder
In the band!
I think there might be too much oil in the crankcase...ill check it once i get my new dipstick. Could that affect the way it runs?
Old March 22nd, 2008, 10:29 PM   #5
88mudder
In the band!
well well...i dont have any vents on my valve covers so i think that explains the system pressure problem.
Now i gotta get the thing tuned..
Old March 22nd, 2008, 11:46 PM   #6
Bronco Ollie
yeah that would do it
Old March 27th, 2008, 10:20 PM   #7
88mudder
In the band!
Originally Posted by mudbillyredneck View Post
set your timming by doing a break-tork with your friend turning the dist (have him stand off to the side, while doing it..:tonka:)
when you can smokem good....it should be close enough....then see if she fires first piston up.(thats a sign of being on the retarded side ).....and if it diesels when you shut it off when warm ( thats a sign of being to far advanced)
I only say this becouse you said you dont or cant get the timming lite to work...this is only good for getting you close, and to see how trusting your friend is :miff:
please be carefull if you decied to do this.....there is nothing cool about messing with your friend while he's under the hood trying to HELP you out....
well ...maybe blasting the horn couldnt hurt....
LOL.
Old March 27th, 2008, 10:24 PM   #8
88mudder
In the band!
well i can rev it up to 4,000 rpm and it doesnt cut out of backfire...idles good, starts up without hitting th gasser pedal...it seems good
Old March 27th, 2008, 10:46 PM   #9
88mudder
In the band!
my lawn mower revs up to 4k rpm and doesnt backfire or cut out too...but I wouldnt call that good....
seams like a stock 302 in a ranger should rev 6,500 and make power all the way to 5,800 at least....but to each there own....
you may be right...but idk. My motor has the stock cam. Im new to v8's so idk what rpm ranges are correct.
Old March 27th, 2008, 11:06 PM   #10
88mudder
In the band!
does it smoke the tires and get sidways down the road......bang 2nd gear and sound like your kicking a pair of basset hounds ??
if not...you might have a puker:stan3:
:miff:
Old March 27th, 2008, 11:09 PM   #11
mudbillyredneck
mudbillyredneck's Avatar
I take that as a no ?.......keep tuning..she may come around.
mudbillyredneck is offline   Reply With Quote
Old March 27th, 2008, 11:11 PM   #12
88mudder
In the band!
it will rev higher...i never said 4,000 was its max. Oh well im sure i got it pretty darn close...ill show u my video soon so u can tell me if it sounds alright
Page generated in 0.23392 seconds with 59 queries
