shaved 14 bolt - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2008, 09:40 AM   #1
chevotass
chevotass's Avatar
Default shaved 14 bolt
heres a few pics of my new 14 bolt. My current one is bent. So i bartered some parts for a new one to build.
starting with shaving almost 2". Ill update pics after new link and shock mounts are done.
BEFORE:
WHAT IVE DONE SO FAR:
Old March 22nd, 2008, 09:43 AM   #2
LILL ZJ
LILL ZJ's Avatar
looks great
LILL ZJ is offline   Reply With Quote
Old March 22nd, 2008, 09:58 AM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
Looks great. How many inches did you save? I need to do this.
Old March 22nd, 2008, 11:21 AM   #4
PavementPounder
PavementPounder's Avatar
You and XJeeper have very similar hacking abilities. :tonka: He took about the same amount off his Dad's axles.
I had some taken off both axles in my XJ. I'm surprised you don't see more people doing this on rigs that they can't get bigger tires under.
Old March 22nd, 2008, 11:43 AM   #5
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
reading its a tuff thing to do.
Old March 22nd, 2008, 03:17 PM   #6
Tab
Tab's Avatar
I did mine too but I only did like an inch and a half or so. I didnt want to deal with welding a new plate on. I left it where there is about .25-.30 left under there. I figured if I was to do it the way you did I would lose whatever thickness the plate I would be welding back on is anyway. Or go all the way and shave the ring gear too. Either way, it looks good.
Old March 22nd, 2008, 03:52 PM   #7
Brods
Originally Posted by chevotass View Post
.... My current one is bent. .....
How did you bend the first one????
Looks good.
Please post some more pictures when you get the ring gear in.
Did you heat the housing before welding the plate to it? What rod did you use to weld it? Let us know how well the welds hold up after a few runs.
Old March 22nd, 2008, 07:48 PM   #8
Blackjackbender
Looks good. about to do the same thing.
debating if i want to turn the ring gear down or not.
Old March 23rd, 2008, 09:05 AM   #9
clarkstoncracker
lol
:tonka: I found it, tanks
Old March 23rd, 2008, 09:56 AM   #10
chevotass
chevotass's Avatar
I decided against turning the ring gear down. I already have a ton of time into it. I did notice that the 5.13 ring has alot rounder outer edge than the stock 4.10. So that gave me a little bit more room.
I used a torch to heat up the housing and burned it in with miller 250. I was going to use arc welder with nickel rod but after doing alot of reading the mig welder should work just as good.
I got my upper link truss done yesterday and gusseted. Cut down the diff cover drilled and tapped 2 new bolt holes and plated the inside bottom of the cover hoping to stiffin it up so it seals. Ill eventually build a new thick cover. but probably not til after this season. Still need to put axle back together and make new link mounts.
should have it done with finished pics by mid week.
Old March 23rd, 2008, 10:56 AM   #11
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Looks good, bent housing sux.
Old March 23rd, 2008, 11:21 AM   #12
chevotass
chevotass's Avatar
yes it does. especially when you dont notice it til after the rig is done and pulled out of the garage. all that work building 4 link and shock mounts are a waste.
the weird part is that i bent the short side. id say its about an inch out of level. its pretty bad now that its sitting on jackstands stripped down.
Old March 23rd, 2008, 01:04 PM   #13
KILLER"B"468
Yankabilly
I ran my bent housing...I saw mine after I welded on all my 4 link stuff for the jeep. And pulled it out of the garage as well. Only 2 times that I could remember it bending in the chevy was... was at top truck or at silver lake It was taken apart that october.
Old March 23rd, 2008, 02:15 PM   #14
Fraser
Fraser's Avatar
http://www..com/viewtopic.php?f=2&t=...&sd=a&start=60
heres a guy to did some shaving on his ball joint 60 front and 10.5", made diff covers, etc
Old March 28th, 2008, 11:59 AM   #15
chevotass
chevotass's Avatar
axle truss is done. and link/shock mounts are done. axle is in and measuring for bumpstop and limit strap mounts.
ring clearance
axle truss. 2x3 box tube. then 3/16 plated the entire thing. this baby is not going anywhere.
axle under measuring for bump stop mounts and limit straps
Old March 28th, 2008, 02:00 PM   #16
Bones
Bones's Avatar
mad flex
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 28th, 2008, 02:06 PM   #17
PavementPounder
How come the truss doesn't reach out onto the driver's side tube?
Old March 28th, 2008, 02:08 PM   #18
chevotass
chevotass's Avatar
bump stop locations. patience my freind. you will see soon.
Old March 28th, 2008, 02:48 PM   #19
Tab
Tab's Avatar
it will explode into six billion pieces because you welded to the housing :tonka: looking good, I need to build a truss for mine too, I was thinking about tying it into the front pinion support bolts.
Old April 3rd, 2008, 12:06 AM   #20
chevotass
chevotass's Avatar
only things left are brake lines, vent tube, limit strap and rear winch.
Page generated in 0.38930 seconds with 83 queries
