garmin 60cs help - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > GPS tracks and trails
GPS tracks and trails 4x4 trails and destination coordinates
Old March 21st, 2008, 01:20 PM   #1
JINX
Default garmin 60cs help
I am unable to connect my GArmin to my laptop.
My computer doesn't recognize the usb
JINX is offline   Reply With Quote
Old March 21st, 2008, 01:40 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Go into your settings on your device and make sure that it's turned on to USB mode.
Play around with those settings and you should be able to get it to connect.
Old March 21st, 2008, 01:45 PM   #3
JINX
I have it set at Garmin
USB says not connected even if I have it plugged into my computer
Old March 22nd, 2008, 09:08 AM   #4
clarkstoncracker
lol
clarkstoncracker's Avatar
Verify your ports are working. Plug in a USB mouse or keyboard to the same USB port
Old March 23rd, 2008, 01:06 PM   #5
JINX
I hvae done that. I even tried using a different computer
Old March 23rd, 2008, 07:30 PM   #6
mudd_jumper
mudd_jumper's Avatar
when you plug something else in does it work?
Old March 24th, 2008, 10:45 AM   #7
JINX
Yes,
I unplugged a working printer from my USB and still nothing
Old March 24th, 2008, 10:55 AM   #8
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Do you have MapSource installed on the computers your connecting the GPS to? It should be as simple as opening MapSource and clicking on one of the buttons in the upper left corner to either send or receive to device and the software should identify and connect to the GPS.
You should also check to see if your unit and MapSource software are up to date.
http://www8.garmin.com/support/colle...t=010-00322-30
http://www8.garmin.com/support/downl...ils.jsp?id=209
One Arm Steve is offline   Reply With Quote
Old March 25th, 2008, 06:04 PM   #9
victorymike
Geocache Addict
victorymike's Avatar
Do you have a PDA installed on your computer. Mine would always steal the port and refuse to give it up until I disabled the PDA from using the USB port.
victorymike is offline   Reply With Quote
Page generated in 0.18575 seconds with 50 queries
